8v and 16v block
  • 12 Replies
  • 3185 Views
Offline Ddog87
  • 109
8v and 16v block
« on: June 05, 2005, 04:23:40 PM »
Are the 16v and 8v blocks the same ?? Thanks
Re: 8v and 16v block
« Reply #1 on: June 05, 2005, 06:08:55 PM »
I think the blocks are but the pistons are diffrent, the 16 valve has four valve reliefs on each piston. also the crank on the 16v might be stronger?
« Reply #2 on: June 05, 2005, 06:21:04 PM »
The blocks are identical, there are
some minor differences in the oil
pump, the 16V oil pump had a crank
position sensor, the 8V does not.
The 16V crank has counter weights
on both sides of the throw, the 8V
has only on one side, I think the 16V
crank would be a little smoother in running
but as far as strength, I see little difference.
The cranks have hollow spots in the throw,
looks wierd, you can look through the throw,
I was wondering if there is a replacement
forged or steel crank available, or is this
something that even has a need ???
« Reply #3 on: June 05, 2005, 07:08:10 PM »
I bet the oil pump you have is 1995 or newer obdII stuff
« Reply #4 on: June 05, 2005, 07:12:08 PM »
Was 95 the eirst year of the 16V ?
I was planning on using the CPS for
the MegaSquirt II Computer to give it
Spark Control info, spark control and
boost retard, I bet I can get a little more
power wiht the milled pistons and some
Computerized spark settings
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: June 05, 2005, 07:34:46 PM »
In OZ the 16v was always in the LWB (mine's a '93) and went into the SWB halfway thru '94.
Offline Ddog87
  • 109
« Reply #6 on: June 06, 2005, 05:49:43 AM »
Soooo the block is the same ??? Can I just put the head off a 16v onto a 8v block? The rig I just bought has a hole in the block. Thanks
Offline HUMZUKI
  • 117
  • Fool!
« Reply #7 on: June 06, 2005, 08:58:02 AM »
Aparently that works,,, it just becomes an interferance engine. I don't think there's much of a gain either. You might be better with a 1.3 head actually (you gain a little compression that way). I here they run better with out holes in them though too ;) ;D
« Last Edit: June 06, 2005, 08:58:58 AM by HUMZUKI »
Offline Ddog87
  • 109
« Reply #8 on: June 06, 2005, 11:34:54 AM »
  GEE THANKS :P But if it didn't have holes in them how would you get fuel in or exhuast out ;D ;D
« Last Edit: June 06, 2005, 11:35:56 AM by ddog87 »
Offline DaddyDave
  • 204
  • Indeed
« Reply #9 on: June 06, 2005, 11:56:56 AM »
how about a stroker motor?  1.3L block with 16 valve crank?  Or is it not worth the time... ???
« Reply #10 on: June 06, 2005, 12:28:42 PM »
I know that they made them in 1992 mine is a 94 and does not have the crank sensor, if you use an 8 valve block you need to use the 16 valve pistons or you might bend a few valves, get an esteem engine and put in there with you other parts on the top end that are diffrent.
Offline zaggy
  • 1134
« Reply #11 on: June 06, 2005, 03:58:40 PM »
1992 was the first year in Canada for the 16v, but only in the 4 door.
Zag
« Reply #12 on: June 06, 2005, 06:00:46 PM »
I tried that, it would take too much machine work,
the block of a 1.3L is about 1 inch shorter than a
1.6L block, as well as the rod journals are smaller
in a 1.3, the wrist pin is smaller, the rods are shorter,
and the pistons would hit the crank if you made a set
of rods to fit the crank.
Best bet, build a 1.6 and be happy.
