NEED HELP 87 Samurai 3/4 throttle at IDLE
  • 15 Replies
  • 5668 Views
Offline essjay
  • 133
Re: NEED HELP 87 Samurai 3/4 throttle at IDLE
« Reply #15 on: November 14, 2009, 02:11:26 PM »
update
Try to start it, and it wouldnt idle, I changed the plugs and that didnt help, I pumped the crap out of it and it would idle for a bit then die, then it started to idle for longer, so I took the fuel line off the carb and sprayed carb choke cleaner in it, it came out into the drivers side barrel, I let it evaporate then I started it, it idled, so I shut it off and started it again, idled really high, so I drove it home it almost died when shifting if the revs dropped in a higher gear, so I kept the revs high, I get home, the idle is normal again, and I can rev it, or tap the gas, and it runs fine.  seems ok now, but I dont trust it..  WTH??
