Alternator
  • 1862 Views
Offline dupont#24
  • 48
  • Deer hunter
Alternator
« on: November 12, 2009, 07:20:36 PM »
I what to use my GM altr when I do my swap from 1.3to1.68vale I am running into this pulley problem it has a v-belt I need a serpentine pulley.Can I drill out the serpentine pulley that came on the 1.6 and put it on the GM altr.Will this work .Or what do yall do  Thanks
Offline dupont#24
  • 48
  • Deer hunter
Re: Alternator
« Reply #1 on: November 13, 2009, 04:33:22 PM »
out of 35 know one has run in to this problem  :(
Offline Longtooth
  • 11
  • Giving the neighbers a show
    • Whats this?
Re: Alternator
« Reply #2 on: November 13, 2009, 09:16:33 PM »
If you can get the pulley on there centered and it doesn't rub on the alternators housing it should work.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Alternator
« Reply #3 on: November 21, 2009, 07:10:37 PM »
I may be wrong but I think you can swap your crank and water pump pulleys on to the 1.6
Student of Now Master of Then
Offline dupont#24
  • 48
  • Deer hunter
Re: Alternator
« Reply #4 on: November 24, 2009, 08:35:01 PM »
I took the pulley off of the 1.6 alternator and had it drilled out to fit the shaft on the GM alternator worked perfect thanks
