body mounts?
  • 1678 Views
Offline smife
  • 179
body mounts?
« on: November 24, 2009, 08:18:59 AM »
I just installed a 3 inch body lift from Calmini. I'm wondering about the body mounts underneath the frame. The bolts supplied in the kit aren"t long enough so I had to take the rubbers off the bottom frame mount. Then I  had to  put the bolts with washers up thru the frame body mounts. Are the bushing supposed to go back on? It seems to me they should but I'm lost.
Also the steering shaft has me puzzled I took the 4 nuts off the middle of the shaft. Do I just put them back on or do I need to extend the steering shaft. I tried searching this but came up with nothing?!?!
Re: body mounts?
« Reply #1 on: November 24, 2009, 08:50:01 AM »
This may be helpfull...
http://www.zukiworld.com/month_100101/feature_spyderman.htm
and be sure to look through the rest of the article archive for more information...
HTH,
Offline smife
  • 179
Re: body mounts?
« Reply #2 on: November 24, 2009, 10:18:12 AM »
Thanks for the link. I'm still kinda lost on the specifics ??? Look at first post
