tailgate rattle..
  • 13 Replies
  • 7097 Views
Offline chevycotton77
  • 88
  • lets go whheellin
tailgate rattle..
« on: November 29, 2009, 02:17:27 PM »
i couldnt find any thing on this in the search.. but does anyone have a way to tighten it up or make it snug so it doesnt rattle so much...all my hinges and everythin is tight and i still cant find the problem..its very annoying and loud when i go on the old loggin roads up here..sounds like its about to fall off..
96 2D Tracker stock, 30" BFG MTs, 6inch calmini combo soon :)
Re: tailgate rattle..
« Reply #1 on: November 29, 2009, 02:46:41 PM »
I thought my hinges were " tight " too. Here's a good test: open the tail gate, so it's 90 degrees from the back of your rig. Grasp it at whatever place is good for you, preferably near the bottom, and try and lift it. If there's any play AT ALL, the hinge bushings are worn. I just took mine apart and redid them after putting up with the rattling and clacking for over a year,
 it finally got too bad. It doesn't take much play in them for the door to make a bunch of noise.
First, I secured the door with some straps to one of my shop rafters to take the weight off it. Then I removed one hinge at a time, disassembled it by removing the round clip holding the pin in, and driving the pin our with a punch. After cleaning the parts up, I could feel the play between the pin and the bushing. I could have went to Napa and bought an oversize bushing, but I found some at my local hardware, and replaced the pins with oversized hardened shouldered bolts. It did require a bit of drilling to get the oversized bushings fit to the hinges, and careful pressing of the bushing into the slightly oversized hole. The hinge material is very soft, and will bend if your ham fisted with it ( ask me how I know.) I ended up using a large socket that fits between the hinge sides to keep it from deforming while pressing in the the new bushing. Sorry no photo's of this, but if you get stuck I could take some tomorrow.
You should be able to find oversized bushings at a good hardware store, and the shouldered bolts, well, that may be a bit harder, but I guess regular bolts would work too. Once I did this NO MORE RATTLES or clacking!
  • 88
  • lets go whheellin
« Reply #2 on: November 29, 2009, 03:30:29 PM »
sweet thanks dude im definantly going to try that out!
Offline fuzzy1
  • 350
« Reply #3 on: November 29, 2009, 07:07:33 PM »
Mine was rattling at the other side from Bentparts, at the striker/latch. Just under the latch on the tailgate is a round rubber bump with a single bolt... on an eccentric. It fits into a 'C' shaped cup just below the striker. I loosened it a tad, turned the rubber piece a little (to a spot that wasn't worn) & after 3 tries of 'too much/not enough' my rattle was gone!! The gate does take a little more 'tug' to open & 'umph' to close, but I like that much more that RRRAAATTTLLLEEESSSS!!! Hth
Fuzz
Non Illegitimi Conterat
Offline jawman
  • 406
  • 1234
« Reply #4 on: December 07, 2009, 07:55:20 PM »
I had that a little when I go over big bumps, but my biggest problem is the sensor at the bottom didn't get pushed in enough for some reason and the interior light was on unless I put a piece of cardboard between the door or left the light off.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: December 08, 2009, 01:28:07 PM »
I thought that rattle was normal?
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline TIMEGH
  • 14
« Reply #6 on: December 08, 2009, 02:00:28 PM »
I played with the round stopper below the hatch and turned the hex stopper above the latch counterclockwise till the rattle stopped.
tim
« Reply #7 on: December 08, 2009, 02:14:15 PM »
tim
Yeah, I tried that multiple times, adjusting the rubber and such. Nothing stopped the rattle and clack until I rebuilt the hinges. It was really worth the effort, it's quiet now. I value that.
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« Reply #8 on: December 08, 2009, 05:33:36 PM »
Yeah, I had that rattle once. Took the back door off and PRESTO! No noise. Worked for the fenders too! ;)
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Offline jawman
  • 406
  • 1234
« Reply #9 on: December 08, 2009, 07:28:55 PM »
that works too.  :P
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Merlin93
« Reply #10 on: December 10, 2009, 03:55:35 PM »
On my Samurai soft top, I replaced the old, hard (LA smog!) rubber bumper, and then moved the lock assembly a _TINY_ bit closer, so now I have to push in on the tailgate, while turning the key, to unlock. Seemed to help on the Samurai.
Offline jawman
  • 406
  • 1234
« Reply #11 on: December 12, 2009, 04:33:37 PM »
thats like a built in security device.on my dads volvo 1800es it has a push button to un latch the door. Nobody except me and him can open it becase you have to turn the button 1/8th of and inch then push on it.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
« Reply #12 on: December 13, 2009, 06:46:08 PM »
You lock your samurai? Weird..... ;)
Offline Merlin93
« Reply #13 on: December 13, 2009, 07:48:45 PM »
OK, I said that wrong.  I have to push IN on the tailgate, while squeezing the handle to open the door.
Sometimes I have been known to lock it -- can't remember when though. But I'm sure I must have, at least  once, somewhere. Maybe when I parked on the street in San Francisco. Or perhaps when the dogs were in back. I'm _pretty_sure_ the key works.  Yeah, it did work when I bought it. I think....
« Last Edit: December 14, 2009, 08:23:30 AM by Merlin93 »
