Stiff throttle pedal
SnowSammi
31
November 29, 2009, 11:01:42 PM »
My 87 Sammi w/stock carb. cable unwound, i replaced it with a Napa cable
pedal very stiff double checked all connections and routing good, help
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
Drone637
8121
116
Evil Cow
Re: Stiff throttle pedal
November 30, 2009, 03:43:02 PM »
You might need to oil it and let the oil work it's way in for a bit. Is it stiff even without it hooked up to the carb?
SnowSammi
31
November 30, 2009, 07:01:04 PM »
I'll try that thank you, no it's not stiff with carb. end unhooked i also
unhooked pedal end with carb. end hooked up feels smooth and normal.
Merlin93
170
4
Reply #3 on:
December 02, 2009, 07:08:47 AM »
More stiff throttle cable discussion at:
http://www.suzuki-forums.com/suzuki-jimny-sierra-samurai-forum/33406-throttle-cable-sticks.html
Turns out the final solution was to get an OEM cable. The aftermarket NAPA cable would last only a very short while.
SnowSammi
31
Reply #4 on:
December 02, 2009, 07:08:48 PM »
Well i tried lubing no help so i will buy an OEM cable like i should have done
from the beginning.
thanks again for everyones input
