Front wheel drive Tracker $300
  • 12 Replies
  • 3231 Views
Offline keith
  • 1176
« on: December 02, 2009, 07:47:25 PM »
Saw this Craigslist add and found it humorous.
http://chicago.craigslist.org/nwi/cto/1492313045.html
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Front wheel drive Tracker $300
« Reply #1 on: December 02, 2009, 08:56:17 PM »
Wow. Its still a good deal for $300. I could part it out for that.
Or I could fix the rear end and make an aircraft out of it. >:D
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: December 02, 2009, 09:04:22 PM »
When my swap was nearly completed but I hadn't yet had the hybrid driveshaft built (or, unfortunately, installed the parking brake cables), I did exactly that.  I large-hoseclamped an aerosol can cap over the rear outlet of the transmission and tooled around in 4WD...er....fwd for a couple hundred miles.  The only downside was that with my non-manual hubs, 4WD was only engaged with the engine running, so if I put the truck in Park and shut off the engine..... Park = Roll.
XL-7 front coils
1.5" rear coil spacers
Offline fuzzy1
  • 350
« Reply #3 on: December 02, 2009, 09:06:32 PM »
Hehe, sad... but yeah for $300 with the already hammered body, could be a good truggy base. Bit of sawzall & tube... Wonder what the frame looks like? *Reads Mike Hagen's mind* "Frame?? We don't need no steenkin FRAME!!" *Chop chop weld weld* "There, that'll fix it!!"  :laugh:
Beercheck, I must admit I've done that too, though with a bronc & only to get home after toasting a rear u-joint. Hey it sure beat walkin!!  ;)
« Last Edit: December 02, 2009, 09:22:07 PM by fuzzy1 »
Non Illegitimi Conterat
Offline jawman
  • 406
  • 1234
« Reply #4 on: December 07, 2009, 07:27:56 PM »
I haven't even seen a trackick in craigslist for that low. Its a great price in the NW. the bad thing is he probably didn't cap off the d-line, but maybe he did.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline AndrewK
  • 81
  • Of COURSE the ice is thick enough..
« Reply #5 on: December 08, 2009, 11:52:10 AM »
I thought most trackicks went that low??   I've either seen them for 500 and under, or the classic CL people " I paid 15,000 10 years ago, so I will go as low as 10,000"
Mine was 400$, saftied, just picked up my girlfriend one for 550.
97 Geo Tracker.  4x4.  5 Speed.  235/75/R15 ATR's, on Cragar 15x8's (a.k.a Jet Puffed).  Custom tubular safari rack. Custom light bar, 4x Baja spots.  Bedliner interior on its way..
Offline jawman
  • 406
  • 1234
« Reply #6 on: December 08, 2009, 07:34:59 PM »
it looks like for some reason there is a bigger value for them in Oregon
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #7 on: December 11, 2009, 05:41:08 AM »
Here's one for sale local to me, I wish I had a few extra bucks....
http://pittsburgh.craigslist.org/cto/1490602756.html
Offline ranger88den
  • 279
« Reply #8 on: December 14, 2009, 08:59:59 AM »
I just picked up a 92 Tracker 2dr. LSI 4wd for $200.  Needs a lot of work including the infamous 'broken clutch pedal/busted firewall" syndrome.
Offline jawman
  • 406
  • 1234
« Reply #9 on: December 16, 2009, 09:15:09 AM »
I have never known about the broken clutch petal?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline AndrewK
  • 81
« Reply #10 on: December 16, 2009, 09:41:57 AM »
hey! mine had that too.  Guess it is common.
Offline ranger88den
  • 279
« Reply #11 on: December 16, 2009, 09:52:40 AM »
Bad clutch cable or a clutch problem causes a restriction in cable operation, hence,  tearing out the firewall and/or breaking the pedal shaft at the lever.  So far I've determined that at least part of the problem was caused by the lever and pedal shaft alignment marks out by 30*.
Offline ranger88den
  • 279
« Reply #12 on: December 16, 2009, 10:09:20 AM »
Here's the lever with the end of the shaft still bolted on and arrows pointing to the alignment marks that are rotated approx. 30*.
