Heat problems with Samurai
  • 3952 Views
« on: December 03, 2009, 11:24:59 AM »
The temperature is hot, the air just doesn't seem to come out where it says it should.  On both the Defrost/Floor and the Defrost setting, it still mostly comes out on the floor with only a very small amount coming out on the windshield.  It's hovering around 0 degrees here at night, so I need defrost.  Is there linkage that needs to be adjusted?
Also, the fan speed is strange..  Off is Off, but any of the other settings is a low speed.  The only way I can get the fan to speed up is to put the slider BETWEEN the positions.  I'm assuming this might be a medium setting..  Do I need a new resistor?
Offline fuzzy1
  • 350
Re: Heat problems with Samurai
« Reply #1 on: December 03, 2009, 01:34:58 PM »
Your description sounds to me like your heater core is clogged with leaves/debris & I'd suspect the switch over the resistor on yours since it works on lower position. You may be able to get the switch open & clean the contacts & realign the lever. Not sure on a Sammy, but on my Tracker & Metro, the switch is sorta sandwiched between 2 pieces of plastic & it seems very sensitive to having the lever pulled outward... Like it's easy to yank the lever itself out of place. Use a pair of bent needlenose pliers to hold the lever while you remove the knob to avoid this. Might be you'll just need to replace the switch. On my Metro, once I got in there I could see the plastic piece that the lever pivots on was broken & all the internal parts were basically scattered. I ended up using a switch out of a Dodge Raider (Mitsu made) & wouldn't you know but the connector was the same... so I ummm 're-engineered' the plastic piece, drilled holes & ran screws through the Metros faceplate to mount the Mitsu switch, & tadaaaa, worked like a charm. The Metro was pretty tanked anyhow so I didn't want to put money into it.
Check on acksfaq.  http://www.acksfaq.com/ Do a search for 'Heater'... he has links showing a way to clean out the heater core as well as fan/resistor problems. Thanks ack!!
Hth
Fuzz
Non Illegitimi Conterat
« Reply #2 on: December 03, 2009, 02:52:55 PM »
Yeah I'm pretty sure that the heater core is clogged, or at least there's a leaf interfering with the fan.  It clicks all the time; apparently it's very common with the Sammys.  I'll check out acksfaq more thoroughly when I get the time.  Thanks.
P.S.  Does anybody know what's up with Zuwharrie?  It's been down all of today.
« Reply #3 on: December 03, 2009, 05:34:32 PM »
What is better than a cold bush?
A warm slamborghin!
Thanks ACK for the heater trick, My white'87 Sammi's heater is blowing good now
Offline jawman
  • 406
  • 1234
« Reply #4 on: December 03, 2009, 06:07:51 PM »
My Geo is doing about the same thing except the fan only works on high and you have to jiggle it to make that work.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline fuzzy1
  • 350
« Reply #5 on: December 03, 2009, 06:10:35 PM »
Yeah I noticed this as well, wondered if it was just my crappy DSL or what... seems to be a virus out there causing ppl problems. Wonder if it's the one mentioned in the water cooler. Grrrr.
« Reply #6 on: December 03, 2009, 07:35:51 PM »
Zuwharrie is back up now.  ;D
I just picked the Sammy up a week ago.. what a great time to buy a topless vehicle with a weak heater in North Dakota!  Maybe that's why I got a good price on it lol.
Offline Cuthulu
  • 384
« Reply #7 on: December 03, 2009, 07:54:21 PM »
I think they call that "Seller motivated"
