Poor Start
  • 2493 Views
Offline Sn0vv
  • 143
    • Cardomain Profile
Poor Start
« on: December 07, 2009, 09:19:28 PM »
Got up to go to work got in my 2000 Tracker turned the key and she turns over, sputters then quits.......took about 5-10 minutes to get her started (IT GOT cold last night) after about 2 seconds running everything is ok.......
Got thinking that it was one of the following
Spark PLugs and Wires.........
Fuel filter Fuel lines or Fuel Injectors...............
what do you guys think the most likely culprit is.....
The day before I did some quick start and stops to move the vehicle (which I should not have done STUPID ME)
quick things to check and try before spending $$$ would be apprieciated
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline IanL
  • 466
Re: Poor Start
« Reply #1 on: December 08, 2009, 12:50:08 AM »
My guess is mainly moisture on the plugs, but could be magnified by old plugs, wires, coil pack insulation, conductive muck around the area....i.e. an accumulation of less than optimum conditions, with the moisture in the cylinders the last straw.
I've found it possible to blow the moisture away by cranking with the throttle open (same drill as for fuel flood).
« Last Edit: December 08, 2009, 12:55:49 AM by IanL »
Offline MikeGV
  • 14
Re: Poor Start
« Reply #2 on: December 08, 2009, 11:20:31 AM »
Well the way i see it :
1) Spark Plug
2) Cold start sensor
3) Injection needs cleaning
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Poor Start
« Reply #3 on: December 09, 2009, 03:27:54 PM »
How many miles are on your truck snowv?  Do you have new plugs in your truck or the originals?
Offline Sn0vv
  • 143
    • Cardomain Profile
Re: Poor Start
« Reply #4 on: December 09, 2009, 09:00:41 PM »
Sorry dont I dont know in miles.......
175000km....I believe that 110000 miles :S
The plugs and wires are definatly not orignals as to when they were changed though I dunno I bought it with 155000kms on it
Offline nprecon
  • 2318
  • 52
Re: Poor Start
« Reply #5 on: December 11, 2009, 11:35:03 AM »
If the PO put a good set of plugs in you should be good to go for another 100K kilometers then.  I just wondered if you were running original plugs in your truck.  These things run forever but they run better with regular maintenance.
Offline Sn0vv
  • 143
    • Cardomain Profile
Re: Poor Start
« Reply #6 on: December 23, 2009, 09:07:56 PM »
IN the end the problem was the fuel filter and probably the quick changing weather along with that.....it has been changed and it running good again...the plugs and wires were changed recently.....as I looked over some canadian tire purchases of spark plugs and wires I kept and noticed the date was recent
Offline johndb
  • 26
Re: Poor Start
« Reply #7 on: December 24, 2009, 09:36:12 AM »
Your truck does not have wires. Glad you got it running good again, it's a good idea to keep gas line antifreeze handy thru the winter months. Up here you should put a half a bottle in every tank to be safe.
Offline Sn0vv
  • 143
    • Cardomain Profile
Re: Poor Start
« Reply #8 on: December 29, 2009, 08:24:21 AM »
I dont use any other chemicals in my gas tank except gas......in the winter I put higher octane in
ment spark plugs only :S
