4WD light on but no 4wd!
  • 1722 Views
Offline bmki21
« on: December 11, 2009, 09:21:46 AM »
Sorry if this is a repost.  I can find info on the blinking light but not if the light is on.  Can somone help?
thanks
Offline IanL
  • 466
Re: 4WD light on but no 4wd!
« Reply #1 on: December 11, 2009, 03:45:39 PM »
Light on means the shift lever is in 4WD and the air-operated clutch valves are in the correct position and holding pressure.  If you have no drive, it is likely that the pneumatic actuator is failing to move the clutch into engagement.
An alternative is that the valves or the actuator are not holding pressure, but the pressure switch has stuck shut.
Both scenarios would require a strip-down job of the front diff.
Offline amforeman
« Reply #2 on: January 10, 2010, 10:38:21 PM »
Did you get your problem fixed.  I am new at this but do understand how the 4wd works.  If you still need help please explain your problem along with what you have done so far. Had it been working and just stopped or has it never worked since you owned the car.  This is needed so I know if someone before you might have modified the 4wd system.
