Some Trailered, Some Drove, I FLEW!!!
  • 9 Replies
  • 3039 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: June 05, 2005, 05:46:10 PM »
"... Digger Air, this is Paragon Tower, you are cleared to land on runway 101..."
What goes up, must come down! LOL!
Just thought I would share a couple of my favorite pics from this weekend's Gonzukin adventure! ;)
Offline 92Sidekick4x4
  • 1456
Re: Some Trailered, Some Drove, I FLEW!!!
« Reply #1 on: June 05, 2005, 05:54:04 PM »
how did the ol silver surfer hold up??? with the coil spacers etc.
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #2 on: June 05, 2005, 07:31:17 PM »
 ;D Cool!
Got any more pics?
[/url]
[/url]
Offline keith
  • 1176
« Reply #3 on: June 06, 2005, 02:48:17 AM »
Where are your top's back sides?  They appear to be rolled up on the top.  How do you do that?
Offline Digger
  • 1991
« Reply #4 on: June 06, 2005, 06:30:05 AM »
I got a ton of pics from this weekend, I just need to go through them and upload the best ones...
The coil spacers held up fine, but I think I blew a wheel bearing. I still have to inspect it close to see what all damage I might have done, but at least it's still in one piece!
Keith, it's pretty easy to "safari-top" like that. Unzip the back window and roll it to the outside so it can tuck between the spare tire and the top of the tailgate. Then unhook/unvelcro the sides and roll them under until it's up to the top. Then I just wrap the "tail" that sticks out the back around the rear hoop and strap it down with small straps(I use MTB toe-clip straps, they are like mini cam-lock straps). For the woods this is plenty, but for the hiway you want to strap the rear hoop down tight to the seatbelt towers to keep tension...
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: June 06, 2005, 08:18:16 AM »
Theres somthing about air pics that I just love. Nice ;D
Mike
Offline Autobot
  • 189
  • Danger Can Happen!
« Reply #6 on: June 06, 2005, 08:56:32 AM »
Doesn't look it from the pictures, but he did get all four tires off the ground too. It was pretty awesome. Yet another advantage of the track/kick, you can use the quad jumps at paragon.  :)
Got Tracker?
2000 2dr. convertible, stock.
Offline Digger
  • 1991
« Reply #7 on: June 06, 2005, 09:05:53 AM »
Mike
Coming from you, I take that as a HUGE compliment! Thanks! ;D ;D ;D
I'm so proud! ;D ;D ;D
Offline Digger
  • 1991
« Reply #8 on: June 06, 2005, 09:37:25 AM »
Damage Report is in!
From what I can tell right now without disassembly, I blew a cv boot on the right front outer, right front wheel bearing needs replaced and the left strut tower is bent almost an inch up!  :o I don't have any cracks in the tower from what I can see, so I should be able to fix it, but what's the best way to bend it back into place? Or should I just leave it there and add an extra strut mount spacer to take up the height? It's giving my left front tire a camber issue /  \ and causing my left front corner of the Tracker to sag pretty good...
« Reply #9 on: June 06, 2005, 03:53:28 PM »
The downside to getting AirBorn.
Ask Mike, I'm sure he knows all about that ;D
