PAINTING STEEL WHEELS
  • 16 Replies
  • 4194 Views
Offline INGERSOL
  • 158
  • BIG, LONG, AND BLACK
    • INGERSOL.COM
« on: July 26, 2004, 02:21:22 AM »
OK, I decided to wait until next year for the new wheel/tires.  But in the meantime, I want to change the look of the truck a little.
I want to paint my steel wheels black.  I hate sanding.  >:( I hate sanding so much.  Any advice on painting a steel wheel (that seems to have a layer of clearcoat on it already) that wont involve sanding?
Has anybody tried to apply rhinoliner or any of that "pickup truck bed spray" stuff to a set of steel wheels?  I hear that stuff is incredibly durable.  I saw a commercial on TV where they sprayed a concrete block with rhinoliner and threw it off a 5 storey building.  The block bounced!  It didn't shatter or crumble...it bounced.  I hear you don't need to do much prep work before applying this stuff (see: I hate sanding comment above).
Any advice opinions?
2003 Chevy Tracker
2.0 L Four Cylinder / 5-speed
Suzisport Headers
K&N Air Filter
Calmini Grill Guard / Tube Bumpers UK Factory Sunvisor RRO Coil Spacers Bridgestone Dueler Revo 235/75-15's
Re: PAINTING STEEL WHEELS
« Reply #1 on: July 26, 2004, 02:32:09 AM »
if you can find a cheap place to do it , have them powdercoated.
Offline INGERSOL
  • 158
    • INGERSOL.COM
« Reply #2 on: July 26, 2004, 03:02:56 AM »
American Racing makes some el-cheapo steel wheels (chrome, white, black) for $50 each. This project involves only my own labour and some paint.  No big dollars.  And powdercoating costs money.
Other suggestions?
2003 Chevy Tracker
Suzisport Headers
K&N Air Filter
Offline d-mcg
  • 51
  • Got Mud?
« Reply #3 on: July 26, 2004, 03:06:15 AM »
you could sandblast them.
Offline INGERSOL
  • 158
    • INGERSOL.COM
« Reply #4 on: July 26, 2004, 03:07:10 AM »
Do you have to remove the tire from the rim to sandblast?
2003 Chevy Tracker
Suzisport Headers
K&N Air Filter
Offline d-mcg
  • 51
  • Got Mud?
« Reply #5 on: July 26, 2004, 03:33:16 AM »
not too sure, but i think it would be a good idea to take the tire off. mabey tape it off?
Offline explosivo
  • 3157
« Reply #6 on: July 26, 2004, 03:40:05 AM »
Tape it at the very least...
omghi2.us[/url]
Offline INGERSOL
  • 158
    • INGERSOL.COM
« Reply #7 on: July 26, 2004, 07:36:33 AM »
Do you have to sand if your going to spray automotive paint onto the wheels?  I hate sanding, and sand blasting will cost money.  Next year I plan on getting a new set of wheels...so this painting thing is just a temporary step until the replacement (thats why is supposed to be a low-bock, no-buck project).
2003 Chevy Tracker
Suzisport Headers
K&N Air Filter
Offline JokerWhiskey
  • 157
  • holy poop! a fuzzy bunny!
« Reply #8 on: July 26, 2004, 07:49:20 AM »
if you're only going to have them for a short time, just rough them up a little with some sandpaper , rinse 'em, throw a coat of primer on them. then spray em with whatever color you're going to use and call it good.
Offline 87Sam87
  • 63
  • '87 Samurai JA and '86 Samurai JX
« Reply #9 on: July 26, 2004, 08:51:06 AM »
You may want to try some Appliance Paint they use for ovens. You can get it at Home Depot. You could also try a heavy duty Epoxy Paint that you can also get at Home Depot. I don't know if you'd have to sand to use these paints or not.
« Reply #10 on: July 26, 2004, 09:07:31 AM »
I use a wire brush attachment on an angle grinder, its a lot faster and a lot less effort than sanding and leaves a nice finish for ther paint to key to. I find the flat type with the wires sticking out the diameter much more effective than the cup type. I prepped an entire 410 chassis using this method, took a while but was a good job.
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #11 on: July 26, 2004, 09:25:13 AM »
Like Rhinoman said, wire wheel on a grinder or you can use one in a drill. I did and it worked great. There is also a product called Liquid Sandpaper and it works fine on stationary stuff but I don't know if it would give a good enough "tooth" for painting wheels.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #12 on: July 26, 2004, 10:21:02 AM »
That's exactly what I do once a year.  My rims look rather sharp, if I do say so myself.  :P
Offline explosivo
  • 3157
« Reply #13 on: July 26, 2004, 10:22:52 AM »
Just grab the wire brush you use to clean your barbeque, rough up the wheels, and brush on Rustoleum ;)
omghi2.us[/url]
Offline 90Stomper
  • 427
« Reply #14 on: July 26, 2004, 01:50:29 PM »
i wanted to do the same thing once and just used soapy water and steel wool, rinsed it off, dried, cut a peice of cardboard like a moon and bought some cheep wally world satin black for about 2 bucks a can.  i just wanted to get through the winter.  they looked so good and lasted almost 4 yrs before i changed them.  no other prep and no primer, they were that crapy silver before. :P
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
