Wheels are 15x7 and 0 offset how much
  • 3080 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: July 26, 2004, 02:34:15 AM »
I want some rims found some they are 15x7 and the offset 0 i want them to be wider and stick out the fenders a bit will these stick out?
01 GRAND VITARA
Offline explosivo
  • 3157
Re: Wheels are 15x7 and 0 offset how much
« Reply #1 on: July 26, 2004, 03:14:28 AM »
Wasn't it established that offset is how far the wheel mounting space was from the center of the wheel? If the wheel has 0 offset, and it is 7" wide, then the backspacing is 3.5". Stock backspacing is 4", and a stock wheel is only 5.5" wide. So, if my calculations are correct, your new wheels will stick out 2.5" further than the stock wheels plus however much farther the tires stick out.
omghi2.us[/url]
Offline JDMCRX
  • 1110
« Reply #2 on: July 26, 2004, 03:28:45 AM »
OK guys figured it out here are the spec on the wheel.
15X7 5-5.5 0 4"back space
so stock is like 4 1/4" this one is 4" but has a 7" surface and stock is 5.5 so this rim is 1.5 wider and so forth.
Cause on my stock rims when i go offroading the tire hits the frame a bit so i guess with this the tire will be 1/4" out more and 1.5 wider :-[
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #3 on: July 26, 2004, 03:29:38 AM »
Its weird tho if the rim is 7" wide and its a 0 offset would the backspacing not be 3.5"??? I dunno
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #4 on: July 26, 2004, 05:13:27 AM »
Ok guys found some rims 15x7 with a 3.75" back spacing and there white ill just spray them black
so i guess they will be out .5" more and 1.5" wider.
01 GRAND VITARA
