water leak under dash
  • 5029 Views
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« on: December 31, 2009, 12:18:29 PM »
i have a 88 Sammy with a soft top can not figure out where the water keeps leaking in on floor board some where under dash. have put new window to tube seal in and it still leaks. please help tirered of having mobile swimming pool.
Suzuzi:: Squeeze between the shit they cant crawl over
Offline cmays03
  • 99
Re: water leak under dash
« Reply #1 on: December 31, 2009, 12:31:48 PM »
I would have to say that there is a rust hole in the cowl where the wiper mechanism is or something like that. I would start looking around that area. Might have to take the dash out to find the leak too.
95 geo tracker sas with dana 30,35 axles 3.55 gears, 33 tsl's, 3 and 4 link suspension. stock motor trans, tcase has 4.24:1 reduction kit.
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #2 on: December 31, 2009, 12:38:36 PM »
well that dont sound fun. is the seal under window frame the usally the problem with this issue
Offline jzap
  • 515
  • How difficult can it be?
« Reply #3 on: January 02, 2010, 09:08:10 PM »
Is the water collecting on the passenger side?  Check the drain in the heater duct.  It can get plugged with leaves and debris.
Jim Z.
66 Apache camper
Offline Amilla
  • 1076
« Reply #4 on: January 03, 2010, 11:30:56 PM »
Just as jzap said.
I had the same problem with my rig.  Ended up poking down into the duct to break the junk around the drain, then followed it up with compressed air.  Good as new!
Amilla
Offline zukimoo
  • 330
« Reply #5 on: January 04, 2010, 06:08:21 AM »
found that I had water coming in the zuke when pulling a turn. The water was going into the open vent on the hood and then pooling there due to clogged drains. It took a while before I had time to get to it so when taking off I'd pull a hard turn to the left and then the water would fall on the passengers feet.....as long as my feet were dry it was all good.
Ended up taking the dash off and while it was out I pulled the heater core and vent. Cleaned the whole thing out and it worked like a charm. I actually has heat after. There was over an inch of dirt on top of the heater core.
06 Baja Buggy
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #6 on: January 04, 2010, 07:24:15 PM »
as a matter of fact it is leaking on the passeneger side going to clean out drains tomarrow thanks for all the help ya all rock
