samurai shifter
  • 2737 Views
samurai shifter
« on: January 03, 2010, 07:16:31 PM »
Does anyone know if the shifter knob from a 90 samurai tintop is a screw on, or if it is glued on. Im having a hell of a time trying to get it off
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: samurai shifter
« Reply #1 on: January 03, 2010, 08:29:03 PM »
Screwed on.  Or in polite circles, threaded.  ;)
I destroyed one in order to find that answer...
It was on a '88 and I was going to swap a nice knob from a '90 with the engraved shift pattern when I chewed the '88 knob  up with adjustable pliers.
I believe they all are threaded.
Ack
Re: samurai shifter
« Reply #2 on: January 03, 2010, 10:23:07 PM »
any suggestions on how to get it off? i dont know if im just lacking the man strength or what.....maybe its locktited on?
Offline zukimoo
  • 330
Re: samurai shifter
« Reply #3 on: January 04, 2010, 06:09:56 AM »
I've used a pipe wrench with a cloth rag to try to stop the scratches. You can heat the shifter arm if you want but be carefull not to melt the knob.
06 Baja Buggy
Re: samurai shifter
« Reply #4 on: January 04, 2010, 09:42:33 AM »
thanks for the suggestion
Offline pprati
Re: samurai shifter
« Reply #5 on: January 07, 2010, 08:25:17 PM »
Take your shifter out of the control tower, put the shifter in a vice(wrap a small shop rag around the stick to prevent the vice from gouging the paint/metal. Use a large pair of channel locks to un-thread the shift knob, if your going to reuse the knob, wrap the knob with a rag to prvent damage while removing it. Hope this helps you!  :)
