Power Steering Issue
  • 2390 Views
Offline Sn0vv
  • 143
    • Cardomain Profile
« on: January 08, 2010, 05:33:22 PM »
At Idle I can turn the wheel all the way left and all the way right with no hiccups .....
WHile driving the wheel will turn then feel really stiff......then loosen again.....happens mostly while applying gas
whats going on here....CHECKLIST
FLuid level-Good
FLuid Quality-Changed every 50000km
Leaks-none
Belt---some signs of wear but no cracks
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline sir lance
  • 342
  • I love my XL-7
Re: Power Steering Issue
« Reply #1 on: January 09, 2010, 01:52:12 PM »
try revving up the engine and turning your wheels at a stand still.
perhaps your pump is failing at higher rpms.
OR your rack is warn out and get stiff under load (driving)
« Last Edit: January 09, 2010, 01:54:31 PM by sir lance »
Offline Sn0vv
  • 143
    • Cardomain Profile
« Reply #2 on: January 19, 2010, 09:30:02 PM »
Sir lance what is most likely to be the pump or the box???
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #3 on: January 20, 2010, 06:21:20 AM »
There is an intermediate shaft that joins the Rack to the steering column. It contains two small u-joints. Remove this shaft from vehicle and check to see if joints move freely in all directions. The one on my 01 seized and caused a problem such as you are having.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline johndb
  • 26
« Reply #4 on: January 21, 2010, 08:28:23 AM »
I sprayed mine with oil to see if it got easier to turn the wheel first. Once it was lubed up I could clearly tell it was the intermediate shaft.
