window
  • 1839 Views
Offline jawman
  • 406
  • 1234
window
« on: January 13, 2010, 05:59:25 PM »
I don't know what is wrong with these window regulators, but they all seem to be bad on almost ever 2dr I have seen. I found one, but is is out of a 4 door and I have a 2 door. will it fit? mine wont go down unless I force it, but it gets jammed both ways BAD. I took the door panel off, but I don't know how to get to the regulator and take it out. can they be fixed or what?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: window
« Reply #1 on: January 13, 2010, 08:04:39 PM »
Ya, they can be fixed, they are cables and they get dry and sticky.
Make sure you lubricate them before the cables get off track and
jammed, they are a real PITA to get back on right.
Remove the door panel, there are several screws that hold it into
place, take the screws out of the window and pull it out of the top,
when the screws are all out of the regulator it can be "folded" slightly
to get it out of the door, I used some WD-40 to get it moving again,
but that won't last, you need a good solvent and oil, I used PB Blaster
last time and then some spray white grease, so far it's working, but I
don't know what would be the best lube for it.
Offline jawman
  • 406
  • 1234
Re: window
« Reply #2 on: January 13, 2010, 09:12:51 PM »
is that also the reason the windows track sideway too or some thing else? I have another one and itslides toward the front about 4 ''.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: window
« Reply #3 on: January 13, 2010, 09:34:55 PM »
Ya, that or the cables are allready off track
