diff breathers! (not really tech)
  • 4319 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: June 04, 2005, 02:51:58 AM »
i have noticed for a while now, that all vitaras have factory front and rear diff breathers, and gearbox and transfer breathers.
although these breather hoses aren't the greatest, nor an ideal length, they do in fact exist, and from factory too i assume, as all vitaras i've had a look under have these. now these aren't modded vits, but vits that chicks drive, and or old people, etc etc.
now, on every sierra/sammy i've seen or worked on, did not have breather hoses fitted. only those pitiful 'breather' caps on top of the diffs.
now, i try to explain this to sierra drivers, that if suzuki built the sierra (solid front axle etc) for more hard core work, and off road duties, then why did they not fit these simple diff seal saving devices?
ok, i understand about the real older models, where no one really knew or cared as much, and seeing as vits started production in, i think 88, why did suzuki not fit breathers to post 88 sierras?
makes you think sometimes. was suzukis vitara destined for a life as we have ours? lifted, locked, and far from stock.
sorry if this isn't really related to much tech (as i know of other forums who dont like non tech threads in tech sections) so yeah.
cheers
Steve
« Last Edit: June 04, 2005, 02:52:48 AM by sikid_01 »
Offline AZKick
  • 39
  • It's paid for now, I can break it.
    • Ckeck out our Teardrops.
Re: diff breathers! (not really tech)
« Reply #1 on: June 04, 2005, 02:43:24 PM »
I did a 2.5" suspension lift and that breather hose just didn't have enough slack to it. Had to put an extention on it.
Offline explosivo
  • 3157
« Reply #2 on: June 04, 2005, 02:49:38 PM »
The Dana 44's I'm putting in my Tracker have those caps, too, as well as the Land Cruiser axle that I have sitting around. When I get them mounted in, I'm going to run a long hose up to prevent contamination of the lube.
omghi2.us[/url]
« Reply #3 on: June 04, 2005, 03:54:17 PM »
I have heard that the stock samurai one's don't leak but then again things do happen, mines 17 years old. I wonder if you could buy new ones?
Offline Utah_Tracker
  • 179
« Reply #4 on: June 05, 2005, 04:17:09 AM »
Back to the purpose of the Thread, ;) Yes it was destiny and all Vits, Track/kicks were ment to be modded and wheeled. ::)
91 soft top Tracker, 3' Calmini Sup, locker around, Auto, & no Power Steering
GO BIG or GO HOME
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #5 on: June 05, 2005, 08:24:03 PM »
;D Amen.
[/url]
[/url]
Offline Mythose
  • 361
« Reply #6 on: June 06, 2005, 05:27:59 AM »
best darned little 4x4 i have ever wheeled.
