cv boots and lift
cv boots and lift
truk1
44
cv boots and lift
January 25, 2010, 05:44:25 PM »
ive got a spacer lift and im having trouble with cv boots tearing. ive went thru two sets .i just installed new boots tonight but they look awful tight. anyone else have this problem? thanks matt ps the lift is one of jeffs 1.5 front 2 rear
Last Edit: January 25, 2010, 06:14:08 PM by truk1
91 sidekick 4x4 header,
jason hutchison
495
5
ZUKIWORLD Staff
Re: cv boots and lift
January 25, 2010, 06:05:58 PM »
put in a smaller spacer. or drop the front diff.
jason hutchison
495
5
ZUKIWORLD Staff
January 25, 2010, 06:25:47 PM »
there is several companies that make the diff drop brackets. none of them advertise here so I'm not inclined to tell you who so you will just have to go surfing.. I gotta support who supports us
some people fab them up by cutting and rewelding the stock ones but from my recollection they are cast and welding to cast iron with any kind of strength can be tricky unless you got skills.
wildgoody
8134
67
Reply #3 on:
January 25, 2010, 07:20:53 PM »
One trick I have used is to loosen the small clamp, and remove it,
then slide the boot over the bump on the shaft towards the CV
joint, this gives it a little more room to move without tearing
