Samurai Power Steering
  • 7611 Views
Offline Dazookster
  • 61
« on: February 01, 2010, 12:22:47 AM »
Aight, so i have the sidekick power steering on my samurai but with 33's its gotten tough to turn i think the pump is going out i was wondering if anyone has upgraded the pump to like a toyota or like an s-10 that has a bit more power cause i don't want to totally redo my steering yet just to have it ready for when i do upgrade any ideas on what would work?
Wahoo for Global Warming more time to go Wheeling
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Samurai Power Steering
« Reply #1 on: February 01, 2010, 08:40:12 AM »
Very good question. I think I have heard of some using toyota power steering although I havent seen anything posted about it anywhere.  I will be keeping a eye on this thread as I would like to move to 33's also.
Offline Dazookster
  • 61
« Reply #2 on: February 01, 2010, 10:21:53 AM »
in my mind as long as you have the hose connections correct that it should work.
Offline john1974
  • 617
    • Zuknation
« Reply #3 on: February 02, 2010, 08:23:02 AM »
I would think so.
Offline Amilla
  • 1076
« Reply #4 on: February 02, 2010, 01:02:57 PM »
I would say add a power steering cooler to your system.  That might help you out, keep the whining and lose of power down.
Toyota power steering is a very common thing to add to Samurais.  Its one of the best upgrades you can do for your steering.  It will handle large tires and its tough as nails.  The box can also be drilled and tapped for hydro assist very easily.
You just need to find an 86+ Toyota power steering setup.
Drill, sleeve, and plate the frame.  Make or buy a pump bracket, and get some hoses made up.  Add a cooler if you would like.
I have it on my rig, have no complaints.  Can steer with my pinkie.
Box, plated/sleeved frame.
Altered the stock Toy pump bracket.
Mounted and ready to go.
Power steering cooler.
Hope that helps out somewhat.
Amilla
Offline jawman
  • 406
  • 1234
« Reply #5 on: February 03, 2010, 12:20:57 PM »
my computer crashed a week ago, so I cant find it right now. anyways there is two modifications you can do to a stock trackick pump to make it handle bigger tires. one mod is putting a washer about the thickness of a penny on top of the spring that controls the pressure bleed off and the other is to drill out one of the ports a little for more fluid capacity. I have not done it my self but there is lots of people that have. maybe someone knows more and can help you out. there is a nice writeup on zukiworld or zuwharrie cant remember what site.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Dazookster
  • 61
« Reply #6 on: February 05, 2010, 11:30:05 PM »
Thanks for the input i'm just waiting on my toyota pulley for the crank
