Xfer Case Fix
  • 13 Replies
  • 4443 Views
Offline zeke1312
  • 17
Xfer Case Fix
« on: February 01, 2010, 06:22:18 AM »
Is already installed in my zuki but the xfe case locked in neutral again. Suggestions? Thank you
Offline oak_raid
  • 193
Re: Xfer Case Fix
« Reply #1 on: February 01, 2010, 09:24:09 AM »
change the shifter sheet?  very easy fix
http://bbs.zuwharrie.com/content/topic,1425.0.html
  • 6597
  • 68
Re: Xfer Case Fix
« Reply #2 on: February 01, 2010, 10:57:27 AM »
You could have worn shift forks. It happens but is pretty rare... You did do the "shifter sheet" fix right? That's where you install an new poly bushing into the ball socket of the case... If you did and it worked for awhile and now you're having problems, it's probaby more serious.
A quick search here on ZUKWORLD resulted in a lot of hits on this...
http://www.zukiworld.com/forum/general-suzuki-forum/transfer-case-stuck-in-netural/msg29021/#msg29021
That thread may help.
Offline zeke1312
  • 17
Re: Xfer Case Fix
« Reply #3 on: February 01, 2010, 07:23:27 PM »
Hi. An "upgraded" shifter sheet was  already installed. The shift forks look clean without any burrs, etc. I plan to install a new shifter sheet. What is the best way to align the shift forks? One note. The small rubber boot was so hard I had to cut it off with a hacksaw! Cutting it with a razor blade didn't work.
  • 6597
  • 68
Re: Xfer Case Fix
« Reply #4 on: February 02, 2010, 11:02:22 AM »
Seriously, read the post and go to the linked post above. Art made a very nice step by step that includes aligning the forks.
Re: Xfer Case Fix
« Reply #5 on: February 02, 2010, 03:45:34 PM »
One issue I have had is with shot t-case bushings or slightly bent t-case mounts.  The shifter can rub against the body when it flexes.  A quick notch with a grinder and all was well.
  • 6597
  • 68
Re: Xfer Case Fix
« Reply #6 on: February 03, 2010, 08:01:49 AM »
Or... you could fix the t-case mounts and bushings! :)
Re: Xfer Case Fix
« Reply #7 on: February 04, 2010, 12:02:31 PM »
Now your just speaking crazy talk.
Offline doughboy0379
  • 290
  • 9
Re: Xfer Case Fix
« Reply #8 on: February 10, 2010, 02:20:00 AM »
Does anyone have any experience with the brass Transfer Case Shifter Sheets that Low Range Offroad Dot Com sells? ??? I changed my sheet a long time ago but I think it is trashed again, I was looking at the brass ones but have no clue if they are any good. I got my first one a polyurethane sheet from Rocky Road and didn't have any issues with it for at least 5 years of wheeling and daily driving.
Re: Xfer Case Fix
« Reply #9 on: February 10, 2010, 11:40:22 AM »
I don't personally have any experience with the brass shifter sheets.  But I have only heard good things about them.  They will never wear out.
Re: Xfer Case Fix
« Reply #10 on: February 10, 2010, 01:22:43 PM »
I'm a fan of poly myself, but 3 club members all run the brass shifter sheet and are happy with it.  As Skyhiranger said, it won't wear out.
  • 290
  • 9
Re: Xfer Case Fix
« Reply #11 on: February 10, 2010, 11:32:04 PM »
Ok thank you guys as soon as I can I will probably get a brass one and try it out.
Offline 240z
Re: Xfer Case Fix
« Reply #12 on: February 11, 2010, 05:13:18 PM »
 I have the brass shifter sheet in one of my rigs, and the urethane in the other.
I prefer the brass, it has more positive feel to it.
Harley Davidson motorcycles......the most efficient way to convert gasoline onto noise,without the side effects of Horsepower!
  • 290
  • 9
Re: Xfer Case Fix
« Reply #13 on: February 16, 2010, 11:43:36 AM »
Thank you 240z another question though, is there a worry about shavings from the brass or is that not a possible problem?
