Driver door falling off (95 tracker) help
  • 2367 Views
Offline Jookycola
  • 372
« on: February 01, 2010, 10:50:16 AM »
It seems like the hinge has come loose or something to that extent.  Is this common?  The roads here in Michigan are brutal so i can see how they could shake loose, i'm just surprised they are.
Is this an easy fix or could it be something far worse?  How would i find out?
  [/url]
  • 6603
  • 69
Re: Driver door falling off (95 tracker) help
« Reply #1 on: February 01, 2010, 10:52:37 AM »
This is a common problem in rust belt areas. The upper hinge rusts out of the a-pillar and can be an extensive repair.
Offline RNAHAKU
« Reply #2 on: February 03, 2010, 09:25:29 PM »
i had the same problem i ground out the rust area opened it up abit with a grinder welded a 3x4 inch piece of sheet metal with 2 bolts weled from the back side just had the leave nuts loosened up close the door and then with the door in the closed postion tightened the nuts relatively easy fix.
89 track
thorley header 2inch flowmaster series 40
calmini hi flow intake
arb front and rear
4.5 rro lift
31x9.5  tsl radial  rock crawler 15x7 2.5 offset
petro cage
Offline Jookycola
  • 372
« Reply #3 on: February 04, 2010, 05:53:15 PM »
Trouble is i don't see any rust at all.  Actually i can't even find where it's loose at.  I just know when i open the door it literally drops a little then opens.  When i go to close it the striker doesn't line up with the door.  And when half way open i can jiggle the door.  but looking at the hinges and where the bolt onto the body i see no movement.  could it be the bolts on the actual door are loose?
  [/url]
