Anybody used 5:71 gears????
  • 2938 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: February 04, 2010, 05:04:44 PM »
hey i was thinking of running trailtoughs toyota 5:71 gears in my toyota axles for the kicker.  has anyone used them and what size tire should i run to keep my low good.
thanks
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Anybody used 5:71 gears????
« Reply #1 on: February 04, 2010, 07:00:13 PM »
I would say that 35's are a good match for those gears depending what you do with the rest of the drivetrain. Lots of people say the 5.71 are weak but I have no personal experience with that. I put 5.29 in mine and run 36's with lots of gearing ahead of the axles. It is a bit of a slug onroad but really shines offroad. Boils down to what you want it to do?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: February 08, 2010, 02:31:25 PM »
k because i was leaving my t-case stock so the 5:71's are going in my axle.  i picked up 33's how bad will those be?
Offline biker
  • 730
« Reply #3 on: February 08, 2010, 08:35:17 PM »
That setup should give you decent power onroad and not be too much at risk of breakage. I would get some stronger birfs if you plan to wheel it much though. Here is a link to my build http://www.zukiworld.com/forum/build-diaries-how-to-diy/project-kickota/
99 Vitara 2wd
10 Gr Vitara
Offline ToyYoda
  • 226
« Reply #4 on: February 08, 2010, 09:41:30 PM »
I have the Trail Tough kit on a X90. Yota axles & 5:71s. 33" is aprox the size tires I run. I don't think the veh. has the power or weight to break the toyota ring/pinion 5:71's . I've gone through 2 automatic trans. & conv. to 5speed. Now on my second one of those & second motor as well ! Diff's ? No problem as of yet. Now how does the gearing work? fine with 33's. I get on flat ground & pull 5th gear no problem. Low range could be better better but 5:71 is as far as I care to go. 35's or taller would be a problem to pull. 8)
