Switched Ignition Source for Aux power?
  • 1654 Views
Offline yellow2000S/R
  • 152
« on: February 08, 2010, 06:45:11 PM »
I need a switched ignition source on my 96 Tracker 16v. I installed electric fans and they run constant once the thermostat for them reaches 180* until it hits 170*.
I currently have it straight to the battery but it runs for 5-10 minutes till it shuts off because I drilled and tapped the housing neck above the stock thermostat and installed the electrical thermostat there for fluid temp. The aluminum housing of the thermostat acts like a huge heat sink and causes the fans to keep running till it cools to 170* or below.
The system has a relay so it's not going to be pulling a lot of power, I just want something to tap into so they shut off with the Tracker as well as make switchable for any water crossings.
Should I just tap into the cig lighter power?
« Last Edit: February 08, 2010, 06:49:24 PM by yellow2000S/R »
Offline yzf438
  • 94
Re: Switched Ignition Source for Aux power?
« Reply #1 on: February 08, 2010, 08:13:55 PM »
what I did on my sami is bought a constant operating soliniod that closes on ignition.  I used the hot wire that ran to altinator
to close the switch on ignition.  wired my elec fuel pump, fan, and alt.  wire off the switch.   ran a heavy wire to the batt.  this way I have a good way to have a switched hot on turning the key on.  works great. been running it that way for a year.
