How to turn off the check engine light?
  • 3120 Views
Offline kotsh
  • 23
« on: July 21, 2004, 02:23:44 AM »
Its a 90' kick.I know why the light went on and i got it covered ,but how do i turn off the light?
thanks all
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: How to turn off the check engine light?
« Reply #1 on: July 21, 2004, 04:30:30 AM »
Depends.  Did it turn on because you "rolled over" a certain odometer reading (like 120,000 miles)?
If so, you can flip the switch under the dash, and turn it off.  If it's because of a real malfunction (like my EGR sensor), then no, you have to FIX the problem for it to go away.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline explosivo
  • 3157
« Reply #2 on: July 21, 2004, 07:50:28 AM »
A screwdriver to remove the guage pod and some nippers to cut the wires ;)
omghi2.us[/url]
Offline kotsh
  • 23
« Reply #3 on: July 21, 2004, 08:05:21 AM »
If so, you can flip the switch under the dash, .
Can you tell me where  this switch is located?
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: July 21, 2004, 11:31:16 AM »
There is a switch under your dash to turn the light off. It comes on every 50, 70, 80, 100k, ect miles. NOTE: The switch is only on 95 and older track kicks.
There are two locations for this switch. One is right behind the plastic dash piece under the steering column. Just pop that peice off, and look for a switch. The other location is right behind the driver's side dash speaker. Take the speaker out and look behind it, to the right.
Hope this helps!
Heather
Heather Galvin
