using water
  • 12 Replies
  • 3284 Views
Offline jawman
  • 406
  • 1234
using water
« on: February 15, 2010, 08:20:59 PM »
I have a 90 trackick that I did the head gasket in about 2 months ago. at starts up a little hard and uses a little water. I followed the directions in the FSM book and made sure the head and block had a flat surface. could there be something else that needs to be checked or did I just do it wrong. I was thinking maybe the intake gasket was bad.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Bobthebiker
Re: using water
« Reply #1 on: February 15, 2010, 08:39:05 PM »
its possible you have a cracked head,  a leaking hose somewhere, water pump leak,  it may be any of a million and 10 things.  pressure test your cooling system to figure it out.
Re: using water
« Reply #2 on: February 15, 2010, 08:41:13 PM »
Recheck the torque on the head bolts
Offline jawman
  • 406
  • 1234
Re: using water
« Reply #3 on: February 16, 2010, 09:14:41 AM »
is the intake gasket a possibility?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline joe dirt
  • 148
Re: using water
« Reply #4 on: February 16, 2010, 04:49:21 PM »
x2 on that..most of the times you have to go through the torque seqence at least 3 times till it checks out...
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Re: using water
« Reply #5 on: February 16, 2010, 06:44:59 PM »
Ya, I think on an 8V the intake could leak by getting sucked into the engine, but
I think you would have a bad miss from that.
Offline jawman
  • 406
  • 1234
Re: using water
« Reply #6 on: February 16, 2010, 09:56:40 PM »
I will check the head bolts again.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: using water
« Reply #7 on: February 16, 2010, 10:12:23 PM »
You should clean and lubricate the threads when reusing head bolts
to make sure you get the proper torque. Torque is the stretch of the
steel in the bolt, kind of like a rubber band, and the force keeps the
parts together.
Offline 89tracker43000
  • 47
  • my tracker
Re: using water
« Reply #8 on: February 17, 2010, 08:20:33 AM »
it could be the tbi gasket or intake gasket when i did my head gasket i replacer both of them and i have not had a problem yet.
Offline jawman
  • 406
  • 1234
Re: using water
« Reply #9 on: February 17, 2010, 11:10:28 AM »
I just re torqued the head bolts and I am going to drive it some more and see what happens. they were all between 40 and 55lbs. after a month of being a DD
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: using water
« Reply #10 on: February 17, 2010, 07:15:30 PM »
The spec is 45-50, I would go a little higher like 55 max to be sure
Offline jawman
  • 406
  • 1234
Re: using water
« Reply #11 on: February 17, 2010, 09:59:03 PM »
that's what I did. my other question is when it is running I was noticing the tail pipe had water coming out of it like a drop of water a second.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: using water
« Reply #12 on: February 18, 2010, 08:58:04 AM »
Engine and exhaust system cold, that is normal, after it is warmed up
you should not see any water dripping, it could be blowing steam tho
and I mean on a warm day, not when it's 30* out
