Rear shocks which ones to use?
  • 11 Replies
  • 3464 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: July 19, 2004, 12:08:58 AM »
Hey guys
What shocks to use in the rear im going to flip the upper strut mount but the rear i heard u can use some crown vic ones? anyone sudjestion?
01 GRAND VITARA
Offline 1bigtracker
  • 3409
Re: Rear shocks which ones to use?
« Reply #1 on: July 19, 2004, 05:29:59 AM »
what year Crown Vic shocks???
stu
Offline JDMCRX
  • 1110
« Reply #2 on: July 19, 2004, 07:09:08 AM »
Yeah what year do we use? for the rear shocks i heard they were longer.
01 GRAND VITARA
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: July 19, 2004, 09:44:00 AM »
I have found that a rancho 5115 works really well in this setup. It's about 2-3 inches longer than the stock shock, so you would gain more travel.
Just ask Speedracer7c how his ranchos are!
Heather
BTW this looks an awful lot like a post in the zuwharrie forum....
:P
;D
« Last Edit: July 19, 2004, 09:44:41 AM by hcgalvin »
Heather Galvin
Offline shoyrtt
  • 161
« Reply #4 on: July 19, 2004, 01:00:41 PM »
Wild has the info on the Crown Vic shocks. ;)
Offline 1bigtracker
  • 3409
« Reply #5 on: July 19, 2004, 02:47:31 PM »
oh i've seen them work in my front yard!  they work awsome but i need somthign cheaper.  i think i might have the most cheaply built rig in the whole fourm!  i love it!
stu
Offline paps133
  • 166
  • make your own road..
« Reply #6 on: July 19, 2004, 02:52:37 PM »
what is this spring of a crown vic, that you guys are talking about???????????
Offline 1bigtracker
  • 3409
« Reply #7 on: July 19, 2004, 02:57:16 PM »
nope, we are talking about the rear shocks
Offline paps133
  • 166
« Reply #8 on: July 19, 2004, 03:05:16 PM »
don't you need longer springs in order to get more flex?
Offline Kreg
  • 795
    • Island 4x4
« Reply #9 on: July 19, 2004, 05:48:19 PM »
You need a long enough spring to keep up with the shock travel. if your shock is too long and your spring is to short, the spring will fall out under full articulation.  :o
Depending on how long/stiff your spring is too, it will lift your truck higher off the ground.
Offline ChileKick
  • 75
  • DIYer Man !
    • Nacion 4x4
« Reply #10 on: July 20, 2004, 04:14:58 PM »
I have a 2 in lift installed and after a lot of seeking for some good but not expensive shocks y found that there are some gabriel vst shocks that work , they just fit in the axle mounts cause they are thicker. This shock are intended for an isuzu trooper , the rear ones and the model is G63519 , they are good , just a bit stiffer than stock ones.
my couple of cents
Custom 5" suspension lift,custom 2"body lift, custom transmision lift,custom intake porting and custom exhaust.
3" wider A-arms custom made front coils.Power inverter , dual batteries , 8000lb winch , VHF , AM , LSB , On board Notebook-GPS on 15" Screen :-)
 265/70 - 15 tires on 8 rims. Custom Man
« Reply #11 on: July 20, 2004, 04:47:27 PM »
Yes the rear shocks from a 98-99 Ford Crown Victoria
work well with 3" spring spacers, the biggest problem
you will have is the drive shaft hangs out and after
50-100 thousand miles it will start to viberate,
like mine  ;D but a spacer should fix this before it
becomes a problem
