95 4-sp auto TCM questions
  • 10 Replies
  • 3814 Views
« on: February 24, 2010, 12:18:12 PM »
Does anyone have any information on what one of these does? I have one on the bench that I'm playing with, I have pulled the code from the software and I'm tracing out the circuitry.  I have a wiring diagram which shows me which pin is which but I could do with some more info from someone with an FSM or who has knowledge of the 4 speed. Here in the UK we see more UFOs than we do auto transmissions.
I have a pin marked 'Light' which goes to the exterior lights system combination switch - Why???
Theres also a connection to the brake light switch - Why???
There is a lamp marked P/N but only the N switch appears to be wired to the TCM, does the lamp do anything in park???
All info gratefully received, details are being published here:
http://www.rhinopower.org/ECUs/TCM_57B40/TCM_57B40.html
Re: 95 4-sp auto TCM questions
« Reply #1 on: February 25, 2010, 03:28:26 AM »
I have a 95 FSM for my 95 Tracker, but it's a 3 speed auto. I've read through it for other jobs many times and never came across any info on the 4 speed auto. That must be for a 4 door? I'll check again later today and see what I can find for you.
« Reply #2 on: February 25, 2010, 04:05:53 AM »
I think its for a 95, this TCM came my way cheaply because the guy that had it didn't know what it was for. I know that there were a couple of people who were interested in fitting a 4-sp into an early model so I thought I'd have a look inside it. Suzukiinfo.com is down at the moment, I'll keep looking and see if I can find any other info.
Thanks
James
Offline cobleeze
  • 29
« Reply #3 on: February 25, 2010, 06:21:21 AM »
« Reply #4 on: February 25, 2010, 06:51:17 AM »
Look here.   http://www.acksfaq.com/trackerfsm.htm
I couldn't find the correct info there. I have found the wiring and some diagnostics info at this site:
http://www.suzuki4x4.net/manual/
I just need to work through it and see if it answers all my questions.
Offline cobleeze
  • 29
« Reply #5 on: February 25, 2010, 08:28:36 AM »
« Reply #6 on: February 25, 2010, 08:59:30 AM »
Well try this one then.   http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm
Does that link work for you? all I get is a red x. I'll try it again when I get home.
Offline cobleeze
  • 29
« Reply #7 on: February 25, 2010, 10:52:01 AM »
Works for me.
« Reply #8 on: February 26, 2010, 04:00:19 PM »
I managed to download the file at home, there is a bit of info in there that should help, thanks. I still don't know why it wants to know that the headlights are on  ???
« Reply #9 on: February 26, 2010, 04:41:00 PM »
That is an odd one.
« Reply #10 on: February 26, 2010, 04:59:22 PM »
I've finished tracing through the circuitry now so I can associate processor pins with functions. I'll feed that into the disassembly of the code and see if any of it makes sense.
