cleaning up wiring?
  • 15 Replies
  • 5354 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
cleaning up wiring?
« on: February 26, 2010, 07:22:45 AM »
so i got my 1.6  16 valve in my 87 sami i was wondering if i could pull some of the old carb wiring        do i use the old computer    little help please
thank you
jon
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: cleaning up wiring?
« Reply #1 on: March 01, 2010, 09:44:13 AM »
no one wow
  • 6602
  • 69
« Reply #2 on: March 01, 2010, 09:58:41 AM »
Yes you can.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #3 on: March 01, 2010, 03:02:59 PM »
do i use both the  sami computer   with the 1.6  or not?
  • 6602
  • 69
« Reply #4 on: March 02, 2010, 08:19:28 AM »
All carburator controls and sensors can be removed including the "ecm". Thinking out loud, if you're not using the power that goes to the original ecm for your new 1.6 ecm, where did you hook it up? Following that through, if the old Samurai ecm doesn't have power anymore it is not serving any purpose.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #5 on: March 02, 2010, 10:36:04 AM »
i got my wiring harness from brent so i tapped in the the wires at the old ecm  i didnt cut any wires thou
thank you eric for helping me
Offline MaddHatter
  • 81
  • Where is the Any Key?
    • MB GRAPHIX
« Reply #6 on: March 02, 2010, 09:06:36 PM »
If you tapped into the wires "at the ECM" then you can just "cut" all the wires at the ECM (after your splice / tap of course).
The Sami ECM is no longer being used. Additionally, you can go through and remove anything on the firewall that is not being used such as the old coil connector, etc. etc.
Offline warbird
  • 110
« Reply #7 on: March 04, 2010, 04:04:35 PM »
looks like this if you do it right   8)
Offline AndrewK
  • 81
  • Of COURSE the ice is thick enough..
« Reply #8 on: March 06, 2010, 08:28:01 AM »
WOW that looks nice
i managed to get my 85 crown vic to look like that, but didnt even want to try with the tracker... But now i will :D
Plus the prev. owner had a hackjob command start put in...and when im working on it, if something brushes the wires, it cranks over.
I make sure to disconnect the battery now. ::)
97 Geo Tracker.  4x4.  5 Speed.  235/75/R15 ATR's, on Cragar 15x8's (a.k.a Jet Puffed).  Custom tubular safari rack. Custom light bar, 4x Baja spots.  Bedliner interior on its way..
Offline my996duc1
  • 222
« Reply #9 on: March 07, 2010, 08:53:07 PM »
Looks great WARBIRD !!!
I thought mine was pretty clean but now I have more work to do  :)
Here is my before with the old 1987 stock engine and now with the 1998 1.6 16v.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline warbird
  • 110
« Reply #10 on: March 08, 2010, 03:23:17 PM »
Nice work!  I see the A/C are you running the power steering too?
Offline my996duc1
  • 222
« Reply #11 on: March 08, 2010, 04:57:50 PM »
yes sir...   ;D
Offline warbird
  • 110
« Reply #12 on: March 09, 2010, 03:25:04 PM »
yes sir...   ;D
What bracket setup are you running (I'm sure it's too tight for pics).  This isn't a total hijack - I'm asking because I want to include the A/C & P/S as options in my wiring manual.
Offline my996duc1
  • 222
« Reply #13 on: March 11, 2010, 07:51:09 AM »
I will try to get some pics for ya (gotta work the rest of the week and weekend).
This was a Petroworks swap so not sure what if any mods were made to the brackets.
Offline my996duc1
  • 222
« Reply #14 on: March 15, 2010, 04:39:47 PM »
here are some pics... sorry for all the muddy water splash in the pics (good time were had).
it was hard to get in there but here are some around the edges of the mess of pulleys all stuck together.
Close to an inch (maybe less but not more, too tight to measure) between the power steering pulley and the ac pulley.
Hope these help.
