2003 Tracker Clutch fluid leak
  • 3117 Views
« on: March 02, 2010, 02:33:12 PM »
Hello,
I had both master and slave cylinders replaced in attempt to cure a leak. Problem still occurs. Where else should we look for a leak? Or is there something else that could cause fluid level to go down?
Bobthebiker
Re: 2003 Tracker Clutch fluid leak
« Reply #1 on: March 02, 2010, 02:42:23 PM »
did you also replace the line between the slave and master cylinders?    if no, you've still got a potential leak point.       or possibly you still have air in the system that must be bled out.
« Reply #2 on: March 02, 2010, 03:10:26 PM »
It was done by a local shop so I will check my invoice. Thanks.
