Urgent Help, Transmission
  • 10 Replies
  • 4341 Views
Offline Zukill
  • 22
  • 1986 Suzuki Samurai
« on: March 02, 2010, 07:02:54 PM »
I just did my replacement shifter bolt, using this sites procedure to do so.
I replaced the bolt, put the housing back on and bolt it up and it wont go into gear/or out of gear
It appears to be in gear since when I start it, let off clutch- it dies.
It free rolls but makes a clunk clunk clunk when doing so.
It does not move when started and attempting.
Please help... it is quite urgent and seems like a fix many of you veterans might know about?
« Last Edit: March 02, 2010, 07:14:06 PM by Zukill »
------Terkill at Tercel4wd-------
---1986---Suzuki---Samurai----
Bobthebiker
Re: Urgent Help, Transmission
« Reply #1 on: March 02, 2010, 07:12:36 PM »
double check your work.  are you 100% sure you've got the right parts in the right spots?
Offline Zukill
  • 22
« Reply #2 on: March 02, 2010, 07:14:59 PM »
All i did was the shifter bolt, nothing else.
From what im aware of, I took it out and put it back the same way.
The original post now has a picture of the transmission looking down
im not 100% sure, i was wondering if someone had some tips or a checklist of some sort to use to make sure.
Offline Zukill
  • 22
« Reply #3 on: March 02, 2010, 08:37:05 PM »
fixed it.
please delete topic, im a dumbass...
Offline PBJ1024
  • 16
« Reply #4 on: March 02, 2010, 08:52:39 PM »
I love it when a plan comes together!   Congrats on the fix!
1987 Samurai
2009 Corvette
2001 Chevy Z-71
2006 Chrysler Sebring Convertible
Offline oak_raid
  • 193
« Reply #5 on: March 02, 2010, 10:10:11 PM »
lol, come on man!  Share the story, we all need a good laugh!
Offline Zukill
  • 22
« Reply #6 on: March 04, 2010, 11:51:40 AM »
lol i clicked it into reverse as i pulled the shifter out
i feel so bad
« Reply #7 on: August 15, 2010, 11:26:53 PM »
i know this is an oollllllllllllldddd thread, but ima jack it anyways because i have the same problem.
for awhile my zuk would have problems with sticking in first gear like it would go into gear too far and would stick so you'd have to take the shifter out and pop it out of gear with a screwdriver, well now it stuck again so we fixed it how we usually do and put it all back together but now it wont wont to go into any gear and is stuck once again in first, cant really seem to figure out what the problem is, any help here guys?
« Reply #8 on: August 15, 2010, 11:39:55 PM »
Sounds like the shifter "sheet" which is a plastic part that holds the
ball portion at the bottom of the shifter, and when it wears the shifter
gets stuck like you are saying.
Contact Hawks Suzuki for a replacement part
888 - samurai
« Reply #9 on: August 16, 2010, 12:03:48 AM »
but how can i get it out of this stuck gear now?
« Reply #10 on: August 16, 2010, 12:12:34 AM »
You need to pull the stick out, click with a screw driver and replace the sheet,
it will not be drivable until fixed
