Flex-a-lite electric fan for 4-door sidekick
  • 20 Replies
  • 6602 Views
Offline wiretap_MD
  • 73
  • Where the Road Ends...Life Begins!
« on: July 05, 2004, 03:25:51 AM »
I'm planning to replace my custom electric fan setup with the Flex-a-lite system.  Has anyone had experience in this? What Flex-a-lite model would fit the 1996 sidekick 1.6L 16v radiator? thank you
'01 Sidekick: OME-Calmini Hybrid Suspension, 1.5-inch spacers, Bilstein 5125 re shocks, 2-inch bodylift, 30x9.5 BFG, Safari Snorkel, ARB bumper, Custom rear bumpe
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Flex-a-lite electric fan for 4-door sidekick
« Reply #1 on: July 05, 2004, 04:52:43 AM »
Im going to be installing my 16" on my 92 sidekick this weekend ill post some pics
01 GRAND VITARA
Offline wiretap_MD
  • 73
« Reply #2 on: July 05, 2004, 07:11:57 AM »
Great! Looking forward to seeing them.  Did you also get the Fan control module as well as the aux manual switch? If yes, kindly post pics of them too. Thanks in advance.
Offline dschwab9
  • 61
    • Zuwharrie.Com
« Reply #3 on: July 05, 2004, 02:35:11 PM »
I have a 97 with a 1.8, and I'm running a generic 16" fan from Advance with a flexalite variable speed controller, and it works great.
One thing I'd recomend is fabbing up a custom bracket to mount it - don't use those things it comes with that poke through the radiator.  The vibration will cause them to gradually fall down the radiator, ripping out fins as they go.
Derek Schwab
Where The Road Ends...Zuwharrie Begins!
http://www.zuwharrie.com
http://bbs.zuwharrie.com
Offline 90Stomper
  • 427
« Reply #4 on: July 05, 2004, 02:38:59 PM »
never had that problem, i love my flex-a-lite fan.  works good and doesnt draw alot of power.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline safarikick
  • 270
  • nor-cal rhinos
Offline explosivo
  • 3157
« Reply #6 on: July 05, 2004, 04:24:50 PM »
How do those electric fans work out in the mud and water?
omghi2.us[/url]
Offline dschwab9
  • 61
    • Zuwharrie.Com
« Reply #7 on: July 05, 2004, 04:42:10 PM »
Have you ever taken it off?  If you do, I bet you'll notice it's moved down 1/4" or so and took out a few fins.
You need to wire up a switch to turn it off if you're going in deep water.  The water can break the blades with they hit it.
« Last Edit: July 05, 2004, 04:42:24 PM by dschwab9 »
Derek Schwab
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #8 on: July 05, 2004, 07:48:06 PM »
Dammit you guys, just when I think that I have all my part needs covered, you go and say:
Now I want one ;D
steveo
Offline wiretap_MD
  • 73
« Reply #9 on: July 06, 2004, 08:45:42 AM »
Thanks for all your input guys.  I really appreciate it.
I've been browsing the flex-a-lite website and I see a lot of models. Have a few questions:
1.  What would be the best model that would fit the sidekick radiator.  I'm thinking of the S-blade model:
2.  What would be the best size that would fit? 14in? 15? 16in?
safarkick:  What flex-a-lite fan model do you have?  Is that the S-fan?
Offline 90Stomper
  • 427
« Reply #10 on: July 06, 2004, 01:18:29 PM »
i got the smallest one, 14in?  its the S one.  it just barly fits top to bottom, plenty of room left to right.  need to get ya some alen bolts to replace the studs that hold on your fan to help with the space between the motor and the fan.  the temp sensor seems kinda cheesy but after 3 months mine is still working great.  i agree that fabing some mounts is a good idea.  i just checked mine and they are ok (fins) but i think i am going to add some mounts this weekend, better safe.....
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #11 on: July 06, 2004, 01:27:57 PM »
i make the ALUMINUM piece
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #12 on: July 06, 2004, 01:35:01 PM »
How are those time wise for installation? How does it rate on the pain in the ass scale?
steveo
95XL7
« Reply #13 on: July 06, 2004, 01:39:31 PM »
I've got dual 12" fans but my radiator is a little wider than the 1.6 radiator.
Offline idaholwb
  • 772
« Reply #14 on: July 06, 2004, 02:14:56 PM »
 I am SOOOOO glad this thread came up so I could see a little more of 95XL7's engine compartment! Every little pic I see of this swap, answers more questions my mind has about the 2.5 going into this 95 4 door I'm going to be doing.
Thank you 95. ;D
97 Sport
265/70-16s
2" lift
2.0 swap
