front difftook a hit
  • 2695 Views
Offline 87zukini
  • 35
« on: March 10, 2010, 10:15:02 AM »
put the samurai on my lift after my last wheeling trip looks like all my front axle parts came just in time. guess i'll see if its striaght after i tear it down
Re: front difftook a hit
« Reply #1 on: March 10, 2010, 01:37:01 PM »
You didn't feel that when it happened? that's why I use skid plates!
« Reply #2 on: March 10, 2010, 01:56:17 PM »
I smashed in my front diff after switching axles and going to Johnson Valley.  Luckily I didn't do enough damage to reach the gears and destroy the ARB, when I got back I removed the diff and beat it back out straight.  Then put the pipe-cap diff protector on from the old axle.
Offline zukimoo
  • 330
« Reply #3 on: March 10, 2010, 04:14:24 PM »
whatch when you're beating it back out because it's very thin.
I'm not sure it happens all the time but I've found some housings that have a dimple in them and they won't take 512/462's without banging out the bump. I had put in a few sets in different zukes with no problem and when I swapped out the housings in the 413K with newer housings I found the gears were locked solid. After looking and trying to figure this out I took it all apart and it was only when I pulled the pot out that I noticed the teeth hitting the front housing cover.
I grabbed the hammer and punch and went to town on the cover...by this time I was a little pissed. I ended up punching a big hole in the front. I went out and bought big pipe covers. Normally these are cut in half and used as armour for their diff covers but I just cut out the rest of the beat up cover and welded the whole heavy cover in its place. I just added a fill plug and watched not to put too mush heat to keep things straight.
I add the armour to all the housings now.
06 Baja Buggy
« Reply #4 on: March 10, 2010, 11:38:58 PM »
I usually use a piece of soft 1x1 wood as a punch so it absorbs most of the shock.  Same thing I use when pounding out body panels.  A rubber mallet helps as well.
Offline 87zukini
  • 35
« Reply #5 on: March 11, 2010, 04:28:05 AM »
as long as its straight im going to cut it out and build my own cover from 1/4" plate . i was driving through a clear cut full of stumps in about 18" of snow. i bounced over a few but neever felt a really solid hit.
« Last Edit: March 11, 2010, 06:07:54 AM by 87zukini »
« Reply #6 on: March 11, 2010, 11:07:57 PM »
as long as its straight im going to cut it out and build my own cover from 1/4" plate.
There is no reason to cut it out unless it is already smashed in.  I would just build your new cover onto the existing system.  Low Range has 3 different designs for you to check out.
http://www.lowrangeoffroad.com/samarmor.htm
Offline 87zukini
  • 35
« Reply #7 on: March 12, 2010, 06:11:59 AM »
look at the pic that bump next to the fill plug is the bolt that holds the lock tab is pushed thru the cover
