Transfer case problems..... help
  • 2988 Views
« on: March 11, 2010, 09:31:38 AM »
So I go to put my samurai into 4 wheel drive last night and it gets stuck in neutral... I can see the fron driveline is spinning but it will not engage into gear cause its stuck in neutral... what do I do? new transfer case? part?
  • 6603
  • 69
Re: Transfer case problems..... help
« Reply #1 on: March 11, 2010, 12:09:50 PM »
This is definitely a question I need to upgrade the FAQ with...
A quick search resulted in 3 or 4 threads on this.
Here's one to get you started.
http://www.zukiworld.com/forum/general-suzuki-forum/transfer-case-stuck/
Good luck! -Eric
Offline zukimoo
  • 330
« Reply #2 on: March 14, 2010, 04:29:33 PM »
mine has been giving me some similar issues and until getting the new case in I've found a temp fix. Take out the t-case lever and then you look into the hole and look at the forks. They need to be in a certain spot to let either one shift. You pull back, push over and then push forward. Sometimes it blocks up. I pull the lever and drop it into the other slot and push it where it needs to be.
After getting it locked a few times I realized that I had 512's in the front and 462's in the rear. I had been looking for the 462's for  a while and they were in the zuke already. I don't drive on the road much so I never noticed. At slow speed it doesn't show at all but it loads the drive train and then you can't just push the lever.
I actually didn't clip the lever back in and just left it sitting.
Oh..the fix is normally to replace the plastic shifter sheet.
06 Baja Buggy
