i hit financial troubles will this gearing work?
  • 11 Replies
  • 3588 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: March 11, 2010, 08:23:07 PM »
so as some of you know i was going to be putting the 5.71 gears in my SAS sidekick with toyo axles but my dirt bike and truck decided not enough attention was on them and broke :'(  i now have to devote some money their way taking away for my project fund.  i really want to atleast get this thing on the ground so i am going to mock it up with the stock 4.10s.  does anyone know if doing transfer case gears or a twin t-case set up wil put me low enough for crawling. i was thinking between 31-33 tires.
thanks jon K
Re: i hit financial troubles will this gearing work?
« Reply #1 on: March 11, 2010, 09:22:03 PM »
4.10 are going to be a struggle in high range, low will be so so ok,
unless you get a set of 4.24 T-case gears, but on road will be a slug
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: March 12, 2010, 07:54:01 AM »
that is what i thought. i wont be driving it much on road, but i am just trying to find the cheapest rout.  i was thinking the 4.24 kit, but doesn't that cost more than doing the diff gears?
Jon K
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #3 on: March 12, 2010, 08:17:21 AM »
there was also a white sidekick that recently did a dual t-case swap. can anyone point me in the direction of his post.  i think he is on 33's.
« Reply #4 on: March 12, 2010, 10:34:41 AM »
Toyota gears will be the cheapest route, 4.24s are about $650
twin T-cases are more and you need new driveshafts again, the
Undertaker is a great way to go but it's $1200, toy gears from
Yukon would be the cheapest route, and get at least 5.83 for
a 33-35 tire, higher if you want to crawl, but you will still want
a set of 4.24s to crawl slow and that adds to the bottom line.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #5 on: March 12, 2010, 02:09:16 PM »
k, cause with the dif rebuild, and gears front and rear it comes out to about 660.  will 4.24s push 33's pretty good with 4.10s?
« Reply #6 on: March 13, 2010, 01:24:57 AM »
not on the street, and just ok in low off road
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #7 on: March 14, 2010, 01:02:51 PM »
ok so 5.71's with 33's and stock t-case gears for now is the way to go. thanks for the info.
Jon K.
« Reply #8 on: March 15, 2010, 12:47:58 AM »
Ya, that should be good, and will be a little lower than stock gearing
on the stock tires, Post some pics when you get putting it back together
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #9 on: March 15, 2010, 11:08:04 AM »
k, i will get those other things paid off then purchase the gears, do you know who has the lower price for the gears, diff rebuild, and knuckle rebuild? i was thinking trailtough.
« Reply #10 on: March 15, 2010, 08:00:10 PM »
Diff gears, Yukon, the other gears are available thru severals
vendors that advertise on this site, you can choose from them,
I would ask about the inventory if you are in a hurry and don't
want any delays in getting the parts
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #11 on: March 16, 2010, 10:26:07 AM »
k sounds good, thanks
