question????
  • 1694 Views
Offline 89tracker43000
  • 47
  • my tracker
question????
« on: March 13, 2010, 01:09:28 PM »
just wanted 2 know if i could use v8 jeep grand cherokee  springs on my 89 tracker?
Re: question????
« Reply #1 on: March 13, 2010, 03:22:17 PM »
fronts or backs and where are they going?
Offline idaholwb
  • 772
Re: question????
« Reply #2 on: March 13, 2010, 05:21:07 PM »
 You can't use them on the front. Too light of a spring rate... You could use them on the rear, but you have to have the bottom of the spring modified to fit the spring cup on the axle properly. Or... You could cut off the old axle spring cups and get some for the rear of a 93-98 Grand Cherokee through Rusty's Offroad (rustysoffroad.com) and weld them onto your axle... That way it would give you just about limitless rear spring choices for spring rate/height...
97 Sport
265/70-16s
2" lift
2.0 swap
  • 47
  • my tracker
Re: question????
« Reply #3 on: March 14, 2010, 06:25:24 PM »
i wanted to know if i could use them on the front and back would the jeep springs be a heaver duty spring because its a heaver vehicle?
Re: question????
« Reply #4 on: March 15, 2010, 12:21:13 AM »
Not heavy duty just higher spring rate, sidekick fronts are about 450 lb per inch
and rears are about 180 lb per inch, don't know what jeep springs are rated at
