1992 head
  • 2532 Views
1992 head
« on: March 14, 2010, 09:52:34 PM »
my 1988 samurai 1.3L engine has died and a friend has a 1992 1.3L that has no intake or distributor will the ones off my 1988 work on it,. I am new at this Suzuki cross over Thank you
Re: 1992 head
« Reply #1 on: March 15, 2010, 12:27:07 AM »
What is the 92 1.3 engine in? I didn't know they still made them (in the US)
in that year unless it was in a Swift.
But to answer your Q, it might, depends on what your putting it into
Re: 1992 head
« Reply #2 on: March 15, 2010, 08:46:42 AM »
its in a Samurai I didn't know if it would bolt up being it was fuel injected throttle body I know the distributor is different the 88 had manual fuel pump and the 92 electric I thought I could take out fuel pump shaft and put a low pressure electric fuel pump in
Re: 1992 head
« Reply #3 on: March 15, 2010, 07:50:29 PM »
Yes, that will work, like you said, you just need a fuel pump.
Check to see if the newer engine has a block off plate, it might
just take your stock fuel pump
Re: 1992 head
« Reply #4 on: March 16, 2010, 08:43:55 AM »
Thanks man I'm going to give it a try when I get time
Re: 1992 head
« Reply #5 on: March 21, 2010, 08:07:14 AM »
The 92 head will have a fuel pump block off plate on it.  The problem will be that the cam doesn't have the lobe to run the carbed fuel pump.  So you will have to either swap heads or cams to run a manual fuel pump.
Heads, intakes, distributors, exhaust manifolds, will all interchange between EFI (90-95) and carbed (86-89) samurais.
