Anyone know what this is called or where to find one?
  • 2816 Views
Offline Zukill
  • 22
  • 1986 Suzuki Samurai
« on: March 16, 2010, 01:18:05 PM »
I was driving around my parking lot and i heard a snap and this appeared on my floor, from this piece.
I can't find it anywhere and it looks impossible to pull out from a junkyard. I'm new to the area so I don't really know where a junk yard would be nearby or if they would even have a samurai laying around.
Thanks if you can help...
------Terkill at Tercel4wd-------
---1986---Suzuki---Samurai----
Bobthebiker
Re: Anyone know what this is called or where to find one?
« Reply #1 on: March 16, 2010, 01:28:01 PM »
that WAS part of your clutch pedal's arm that pulls the cable.   you might be able to order one from suzuki,  or perhaps talk to someone parting one out here.
Offline Zukill
  • 22
« Reply #2 on: March 16, 2010, 01:50:19 PM »
is there a specific name or number that it's defined as to make the dealer/web site part search a bit easier because im not having much luck with my bland names for it.
Bobthebiker
« Reply #3 on: March 16, 2010, 02:04:03 PM »
Honestly?  I havent a clue if theres some real part name for it.   if you can find a part number on it, you're set.
Offline blknight87
  • 417
« Reply #4 on: March 16, 2010, 02:59:42 PM »
I believe I have one sitting in the garage... shoot me a pm, with a zip and an offer... I will get it on it's way to you asap!
87 sammy-JX
U4WDA/IBZK
1.6 8V w/ MY-SIDE2-44mm SE carb
Thorley Header
Rebuilt trans, and t-case w/6.5-1's
SPOA 6"s w/ Rancho springs
275-85-15's buckshot mudders
Rino Line
RIP "BLKNIGHT" FOR YOU ARE MISSED
Offline zukimoo
  • 330
« Reply #5 on: March 18, 2010, 05:36:08 PM »
is that a samurai or tracker? I had a set of pedals in my hands an hour ago.
06 Baja Buggy
Offline jeff1997
  • 1228
  • 27
« Reply #6 on: March 19, 2010, 08:25:25 AM »
Those parts are prone to breakage. Mine actually broke twice. I welded it the 1st time but then I bent new metal around it and welded it to the break the second time. In my opinion that design is a little weak.
3" Masterkit1 body lift
Custom strut spacers
Offline Zukill
  • 22
« Reply #7 on: March 23, 2010, 10:48:32 AM »
1986 samurai
its the bracket that holds the clutch cable and slips over the splined shaft the clutch pedal is on.
i agree it is a poor design but your fix helps and gives me an idea! im in sort of a hurry and been looking for a fix...
thank you sir, im going to try going to a shop tonight and see if i can get it welded
