Rino Linerering
  • 12 Replies
  • 3918 Views
Offline SidekickMN
  • 58
  • Waiting on  Money  for  Body Lift
Rino Linerering
« on: June 01, 2005, 02:28:28 PM »
hey guys ive heard of people puting rino linering  in there sidekick im planing on  doing it soon so could i seee some pictures of it thank you :)
1994 Sidekick, hard top, soft top, custom bikini top
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
Offline 92Sidekick4x4
  • 1456
Re: Rino Linerering
« Reply #1 on: June 01, 2005, 03:45:49 PM »
maybe do a search, i think there have been a few threads about this.
Offline kansascitytracker
  • 335
  • 92 Tracker
Re: Rino Linerering
« Reply #2 on: June 02, 2005, 05:28:38 AM »
I am thinking of taking out all the seats and carpet and Rhinolining mine. Afterwards, the backseat would be left out. I have heard there are drain holes in the cab, is that true?
  • 1456
Re: Rino Linerering
« Reply #3 on: June 02, 2005, 08:16:52 AM »
yes there are drain holes im nto sure how many there are but thewre r 2 for sure in the back and i think theres more in the middle and front etc.
Offline bus_driver
  • 479
  • the voices tell me different things
Re: Rino Linerering
« Reply #4 on: June 02, 2005, 09:42:28 AM »
when you pull up the carpet you will see the rubber stops for the drains....
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: Rino Linerering
« Reply #5 on: June 02, 2005, 11:03:00 AM »
there should be 6 drain holes in the floor pan, two in front of the front seats, two behind the front seats and 2 under the back seats.
6 unless you find rust, and then its all cutom from there on.
taking the carpet out was the 1st thing i did the second day i got my vit. also, if you plan on hosing the floor out once in a while, maybe hose it out before the rhino liner, and see where the water pools up. if your happy with it, or if you have a water/aqua vac, then its all good. sometimes i have a hard time getting rid of all the water, as the floor does not always run towards the drain holes.
probably the easiest way to hose out the floor, is to have either front wheels on ramps, or the rear wheels on ramps. this way, you will have ALL the water at the front or at the back of the floor. aqua vac saves a lot of stuffing around.
Offline SidekickMN
  • 58
Re: Rino Linerering
« Reply #6 on: June 02, 2005, 02:21:16 PM »
thanks for all the advice going  to  do  it  this weekend hopefully
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
Offline bus_driver
  • 479
Re: Rino Linerering
« Reply #7 on: June 02, 2005, 03:31:59 PM »
 ru doin it on your own ???? wherer and how much did you buy the rhino stuff for.....friend paid too much money too get someone to do it
92 2dr soft top
235/75/15
2 inch lift
custom mud
  • 1456
Re: Rino Linerering
« Reply #8 on: June 02, 2005, 05:42:26 PM »
you can get kits at candaintire, they call it hippo liner i belive, u can make it any color
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
Re: Rino Linerering
« Reply #9 on: June 03, 2005, 12:17:45 AM »
Is lining the floor a great way to soundproof the cab?
[/url]
[/url]
Offline adamd
  • 369
  • sofa king we todd it
Re: Rino Linerering
« Reply #10 on: June 03, 2005, 12:33:35 AM »
look into stuff called durabak.
'98 kick
3" B/l
30" Mud Kings
Offline PWSX3
  • If it's a 4-wheel drive it should be off-road
Re: Rino Linerering
« Reply #11 on: June 05, 2005, 01:43:21 AM »
We used Hurculiner, took 2 quarts cost was around $70.00 you will pay a LOT more for any spray on material but the spray on will look nicer. I have heard Hurculiner is one of the better ones as long as you want black.
1987 stock for now Sami for my 15 year old's first vehicle.
We Wheel with a 1994 Ford Explorer 5" Superlift, 35" tires, locked in the rear, custom tire rack, sliders, misc. stuff.
Offline BLK_ARMR
  • 175
  • Herculiner All The Way!!
Re: Rino Linerering
« Reply #12 on: June 05, 2005, 10:08:43 AM »
I used Herculiner as well...all over the outside  ;D  I rolled 3 coats onto the body of my Track/Kick.  Took me about 1.5-1.75 Gallons.  Caught the kits on sale at Northern Tool for $50/Gal.  ;D  Went on rather well, just a lot of prep work.  Make sure you rough it up really well.  I would use 80 grit sandpaper.  They include scotch brite, but that isn't rough enough IMHO.  So far it's holding up well.  After about 6 months it flattened out and isn't shiny like it used to be but that's the way I wanted it anyway.  You can buy the UV Topcoat to restore it's shine also.  Herculiner can also be sprayed if you have the facility to do it.  Just need an air compressor and an undercoating gun (cheap) and a place you can make a mess...LOL.  Spraying makes it a lot more even, but I didn't have anywehre to do it.  And Line X estimated at least $1500-2000 for teh whole truck.  No thanks!
Bryan
93 Tracker
Coated in **HERCULINER**
2pc Hard Top, Flares, 3" Body Lift, 31"x10.50" OTR Muds, 15"x8" Black "Wagon Wheels"
