rebuild question??
  • 1850 Views
Offline 89tracker43000
  • 47
  • my tracker
rebuild question??
« on: March 28, 2010, 02:35:21 PM »
hi all i have an 8v motor i want to re build to put in my tracker what all should i replace when im in there the motor does run. i would like good valves and good springs and a cam. where could i get a cam at for my tracker?? thanks
Re: rebuild question??
« Reply #1 on: March 29, 2010, 06:06:06 AM »
For a cam and valves you could try contacting Sammypro.com, thats also his username on here. Otherwise there is Superf1y on the teamswift.net forum for cams and valves. Calmini and Trail Tough supply cams but the other two will most likely be able to supply you with good advice as well as parts.
« Last Edit: March 29, 2010, 06:07:44 AM by Rhinoman »
  • 47
  • my tracker
« Reply #2 on: March 30, 2010, 06:43:25 AM »
thanks
Offline 95Gstman
  • 78
« Reply #3 on: March 30, 2010, 09:55:16 AM »
I got a remaned head from hawk and my machineist said that it was a very good price and he would probably would not have been able to do it for me any cheaper than that. Hawk also has cams and will give you good advice.
http://www.hawksuzukiparts.com/
