will this fit?
  • 11 Replies
  • 3141 Views
Offline trailboss
  • 23
will this fit?
« on: July 12, 2004, 04:32:24 PM »
will Trail Toughs yj lift kit fit a 1995. i finaly found a 1995 sami for sale very close to me so i mint buy it but just making sure all the good aftermarket parts will fit it and is a 95 good year of the sammy or should i try to get one thats older? please help sorry for all the questions
Offline zookiemike
  • 474
  • $,reppin Michigan,$
Re: will this fit?
« Reply #1 on: July 12, 2004, 04:42:40 PM »
the front diff is only 2 pin but snag it up. And all the the cool stuff will work ;D
Offline trailboss
  • 23
Re: will this fit?
« Reply #2 on: July 12, 2004, 04:57:06 PM »
what do you mean 2 pin in the front are you talkin about the pinions and is it bad that it only has 2? sorry for dumb quetion but im confused thanks.
Offline zookiemike
  • 474
Re: will this fit?
« Reply #3 on: July 12, 2004, 05:02:41 PM »
In an older sammy there are 4pins for the spider gears. The 91 and up has two pin carriers. So there are only two spider gears. As far as being a bad thing. If you want to put a locker in the front you need a 4pin. It'll be okay for awhile even with some good use. ;D
Offline zookiemike
  • 474
Re: will this fit?
« Reply #4 on: July 12, 2004, 05:06:33 PM »
I might be wrong so dont take my word on the carriers :-[. But the lift stuff will work. 95,s are sweet. 8)
« Last Edit: July 12, 2004, 05:06:58 PM by zookiemike »
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: will this fit?
« Reply #5 on: July 12, 2004, 06:51:32 PM »
 Snag it quick, Fuel injection is the ticket. The vehicle is worth the extra cash, don't be fooled by our carbed brethern. Suspension will work just fine and you can always upgrade the front to arb locker and not worry about the stock carrier.
Offline supazuk
  • git 'er done!
Re: will this fit?
« Reply #6 on: July 13, 2004, 02:34:54 AM »
I have a 94  exactly the same its great and i have the TT yj in the rear spoa  yes its 2 pin but unless you want a front locker  that just fine I have a TT hybrd rear locked   with 5.13 and a 4 pin front withthe same so that is solved only down side is no back seat but thats ok jsut drill holes and put one in .. or just use it for tools
get it quick thats the best looking grill IMHO
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
Re: will this fit?
« Reply #7 on: July 13, 2004, 05:04:06 PM »
Do they sell different front lockers for the 91 and newer, or are they the same? Is that 2 pin any weaker then the 4 pin, or is it 2 stronger pins? Just wondering because i have a 91, and was contemplating the lockers. I was just going to weld the thing, the cheaper the better thats the lakeview motorsports way!
"I do what I want"
LMS wasted my time
Offline idaholwb
  • 772
Re: will this fit?
« Reply #8 on: July 13, 2004, 06:22:06 PM »
 2 pins the same size, only half as many as the earlier ones. There is no locker for the 2 pin.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline LawDog
  • 531
    • Emerling Chevrolet
Re: will this fit?
« Reply #9 on: July 14, 2004, 05:08:58 AM »
I wonder if you could swap in the 4-pin setup??
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: will this fit?
« Reply #10 on: July 14, 2004, 07:29:09 AM »
2 pins r fine i run 33 on my 95 and a 1.6 16 valve that bolts right to the fuelinjection and computer. i haven't broke anything but hub fuses. thoser things save alot of axles.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline supazuk
  • git 'er done!
Re: will this fit?
« Reply #11 on: July 14, 2004, 08:44:28 AM »
diffs will swap out evenly....  thats what I have done
