need help with rear spring
  • 2032 Views
Offline safarikick
  • 270
  • nor-cal rhinos
« on: March 29, 2010, 06:41:46 PM »
hi
   i have a 97 sidekick with a 3 in calmini lift. i have a made a rear bumper and  tire rack. I have gear in the back of the truck  it will sit low in the back. i was thing of using air lift bag inside of the rear coil spings.
http://www.summitracing.com/parts/AIR-60793/
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: need help with rear spring
« Reply #1 on: March 29, 2010, 08:32:39 PM »
the air bag will not be tall enough. your best bet is a higher PPI spring rate.
kevin
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: March 30, 2010, 12:12:46 PM »
Maybe a spring spacer in the rear only?  Just a guess.  That would give you more height ALL the time though, but could help it sit a little better when loaded.  It'd be cheap.  Just a thought
