JA(coil spring) body on SJ(leaf spring) chassis/frame. IS IT POSSIBLE
  • 1673 Views
Offline pabloT
I have a JA12 body in very good condition, its from a coil spring samurai. I am wondering if it"s possible to replace my old worn out SJ body with it.  The SJ is a leaf spring chassis/frame.
Is it possible or would there be problems.
Re: JA(coil spring) body on SJ(leaf spring) chassis/frame. IS IT POSSIBLE
« Reply #1 on: March 29, 2010, 11:25:22 PM »
It should be possible, the body panels look to be the same.  Might be a slight difference with the inner fender well.
Body swaps between years can be a pain though.  Sometimes there is a lot of electrical that has changed that isn't documented particularly well.  You might be better off putting your drivetrain into the coil spring SJ.
Offline pabloT
« Reply #2 on: March 30, 2010, 07:40:10 AM »
Was thinking about the drivetrain instead but wasn't sure.
