1990 Sidekick idling problem.
  • 3693 Views
Offline junkman
  • 73
  • Old stuff is OK
« on: March 30, 2010, 11:22:52 AM »
I have a 1990 Sidekick that is constantly idling up and down. It runs from 1000 rpm to 2000 rpm constantly. I have been told that it is the throttle positioning sensor. Does that sound like what it is? They are $170.00 and I don't want to buy one if it is not the problem. If this is not it, what else could it be?
Junkman
One man's junk is parts for another man's 'kick!
Re: 1990 Sidekick idling problem.
« Reply #1 on: March 30, 2010, 02:18:20 PM »
I would say that its probably not the TPS if its an idle problem and the TPS is correctly adjusted. have you got a Check Engine Light on? Take a look at this site:
http://www.kick-fix.com
Offline junkman
  • 73
  • Old stuff is OK
« Reply #2 on: March 31, 2010, 04:44:27 AM »
Thanks! I'll give it a try.
scentral mt
« Reply #3 on: March 31, 2010, 08:42:16 AM »
I had this problem with my 1990 Tracker.  One thing I found mentioned was vacuum leaks.  Mine would do it until it was warmed up.  I also had a high idle on startup.  Both these problems were fixed when I blocked off the air to the wax pellet that controls the high idle.
 It's to the passenger side of the tps.  A cover with 3 screws, remove the cover and there is a spring loaded valve  and the wax pellet is behind that.  I have a factory service manual that showed how it looks.  I used a piece of rubber hose ---with a small bolt part way through to keep it straight--- to fit over the opening to block off the air.  I needs to be about 1" long.
This fixed the idle problem.  No more surging and no 3000 rpm on start-up.  It won't have a fast idle when cold but I haven't had problems with that since these engines warm up pretty fast.
You can search for "wax pellet"  or check out this
 http://www.zukiworld.com/forum/general-suzuki-forum/wax-pellethigh-idle-fix/msg93396/#msg93396
Hope this helps.
Offline junkman
  • 73
  • Old stuff is OK
« Reply #4 on: April 06, 2010, 04:07:45 AM »
Hey! Thanks alot! That was exactly what was wrong.
Junkman
