Front Steering Knuckles
  • 11 Replies
  • 5629 Views
Offline 87Sam87
  • 63
  • '87 Samurai JA and '86 Samurai JX
« on: July 11, 2004, 01:13:50 PM »
  Can anyone tell me how the front steering knuckles recieve lubrication? Is it supplied from the front differential?
Thx
Offline 1bigtracker
  • 3409
Re: Front Steering Knuckles
« Reply #1 on: July 11, 2004, 01:15:17 PM »
i am 99.9% sure it is lubed by the 90W lube in you diff.
stu
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #2 on: July 11, 2004, 03:23:42 PM »
Negative on the gear oil. Upon assembly the knuckle and birfield joint are packed with grease.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline 87Sam87
  • 63
« Reply #3 on: July 11, 2004, 07:35:25 PM »
   Is there any kind of maintenance that I need to do on them? I'm not seeing any grease zerks or anything. It does look like there's still lubrication in there as the knuckles have grease on them.
Thanks for the help.
Offline idaholwb
  • 772
« Reply #4 on: July 11, 2004, 08:02:32 PM »
 I believe that every 60-70,000 miles or so you need to take the knuckle apart and repack the bearings and replace the seals. Mind you I have only seen a couple actually have this done, and most of the time it was because the front end needed to be rebuilt anyway because of the infamous death wobble that normally happens on a wore out front end about 35-40 mph. You can buy a complete front knuckle rebuild kit from Brent at www.trailtough.com. for about $200.00 plus shipping. It has wheel bearings, trunion bearings, and all the paper-rubber-and felt seals related to the whole mess.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline zooky
  • 135
« Reply #5 on: July 11, 2004, 10:17:40 PM »
stu
.1%, what are the odds!? ;D
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #6 on: July 11, 2004, 10:25:30 PM »
Plz go into a bit more detail on this "infamous death wobble"...
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #7 on: July 12, 2004, 10:54:29 AM »
I would recommend a repack at least as often as the afore mentioned 60-70k, otherwise, well idaho put it best...
Offline Rollerskate
« Reply #8 on: July 12, 2004, 04:05:03 PM »
Actually,the knuckles are lubricated with gear oil.But only
when the inner shaft seals are shot. ;D
I never asked for nothing and thats all I got.
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: July 12, 2004, 04:38:19 PM »
Im not to sure about that but my geuss is the wheel bearings. Allmost ever samurai ive ownd has sloppy ones. Just jack the front end up and grab the tires at 12;00 and 6;00. if you got play tightin them. allso check the stearing box. the little screw does the addustment
« Last Edit: July 12, 2004, 04:40:47 PM by zookiemike »
Offline tsleong
  • 66
  • I love zuk
« Reply #10 on: July 12, 2004, 05:48:44 PM »
It may be also due to knuckle bearing. Failure indication is when gear oil start to leak from the knuckle. It is then time to rebuilt with new bearing and grease. When knuckle bearing fail, the knuckle is loose and sit higher, forcing the half shaft to be higher and oil to leak past the seal on the bottom of half shaft.
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #11 on: July 13, 2004, 06:32:24 AM »
rebuilding knuckles is a bunch of fun!
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
