stalls in gear
  • 2966 Views
Offline crgm101
  • 80
stalls in gear
« on: April 09, 2010, 07:57:54 PM »
i have a 1986 suzuki samuraI WITH 1.3 LT MOTOR MANUAL TRANSMISSION AND WEBER CARB
MY PROBLEM IS WHEN I REV UP THE TRUCK IN NUETRAL IT WORKS PERFECT WHEN I PUT IT IN FIRST AND TRY TO TAKE OFF IT STALLS THEN RESTARTS AND RUNS REALLY ROUGH UNLESS I FLOOR IT THEN IT RUNS PERFECT AGAIN IT DOES IT IN ALL GEARS AND WHILE CRUISING AT SAY 45 IT RUNS TURNS OFF AND THEN RUNS AGAIN PLEASE HELP
 so far i have put a new coil,cap,rotor,wires,fuel filter and checked fuel pressure i also wired the coil and distributor to direct power to make sure it wasnt a computer problem i dont have a catylitic converter ai run a flex pipe from the headers to a harley exhaust this is my daily driver and has ran perfect since i rebuilt the motor 6 months ago until this morning thanks for the help and i hope i got all the info you need
Bobthebiker
Re: stalls in gear
« Reply #1 on: April 09, 2010, 08:33:43 PM »
only thing I can imagine is weak fuel pressure, or a clog somewhere in your fuel line that you're not aware of.   most likely at the carb itself.
Offline crgm101
  • 80
Re: stalls in gear
« Reply #2 on: April 09, 2010, 08:53:36 PM »
i pulled of the fuel line from the carb and turned on my fuel pump and it had good pressure up to there about 10 psi if i held my thumb over the end of the line and if i removed it it would spray about a foot out of the line when the engine is running it sits at 6 psi exactly thanks to a inline holley regulator and fuel pressure gauge. but thanks for the thought im at a loss to and i know my samurai better than my wife
Re: stalls in gear
« Reply #3 on: April 09, 2010, 09:48:22 PM »
Look for water or crap in the carb, that's the only thing that I can think of
Bobthebiker
Re: stalls in gear
« Reply #4 on: April 09, 2010, 10:07:11 PM »
by chance did any previous owner modify any wiring?   its not uncommon for issues of this sort to be tied directly to shoddy wiring modifications done by ghetto engineers.
Offline fuzzy1
  • 350
Re: stalls in gear
« Reply #5 on: April 10, 2010, 08:41:55 AM »
Sounds to me more like it's flooding, Ive run a weber carb before & it was recommended to run 2-3 psi. If the regulator is adjustable, try turning it down & see what happens. Hth
Fuzz
Non Illegitimi Conterat
Offline crgm101
  • 80
Re: stalls in gear
« Reply #6 on: April 10, 2010, 06:56:40 PM »
figured it out oday at lunch my pcv valve went bad i capped it with a rubber seal and now everything is back to normal and a replacement valve is 1.15 at autozone its always the cheapest thing thanks for everyones help
