drum roll please...=)
  • 35 Replies
  • 7930 Views
Offline Mike71
  • 1449
« on: July 10, 2004, 12:33:58 PM »
ok after a long debate over turbos..and bimmers mercs and lades i have decided today to not buy a new car..but to go solid instead  ;D idaholwb is the one to blame for that =)...going full kicker 3...duel t cases locked front and rear =) bout 6" sus lift with a 3" bl =) will run 35"s on the street and 33"s for the trail =)
idaholwb will have to chime in on any specifics since we didnt really get into huge detail..we are going to start with the sammy case and front housing in 2 weeks =)
yay yay yay...also on a side note im finall going to get a damn vent for my moms car!!!! lol
ldaho..you da man =)
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: drum roll please...=)
« Reply #1 on: July 10, 2004, 02:53:45 PM »
We need plenty of pictures! ;)
Offline 1bigtracker
  • 3409
« Reply #2 on: July 10, 2004, 03:15:16 PM »
another SAS, man Idaholwb must be making some good paper off their SAS swaps. ;D  i still wana go SAS but i think i might run into the same probs i'm having right now. i'll sty IFS for the time being.
stu
Offline explosivo
  • 3157
« Reply #3 on: July 10, 2004, 03:21:05 PM »
Isn't that a requirement for a project this big? ;) :)
Hope everything works out for ya on your project, Mike ;D
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #4 on: July 10, 2004, 05:11:36 PM »
 Paper's not in the bank yet, still stuck in the wind.
;D
The more the merrier(I am)! 8)
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Natebert
  • 1098
« Reply #5 on: July 10, 2004, 07:45:10 PM »
Be sure to get extra width and strength in the axles.
The stock width and strength just isn't enough.
If I had it to do all over again I'da gone with the toyota t-case kicker, and fullsize landcruiser axles.
You'll thank me.
~Nater
Offline idaholwb
  • 772
« Reply #6 on: July 10, 2004, 08:27:16 PM »
 In the coil front suspension theory, the rubbing problem you have, won't be a problem. As far as strength goes, as far as I know, you have only broken a rear stock axle shaft, right?
And doesn't Toy stuff still break birfs with 4 cyls. anyway? And aren't the Toy axles like very expensive to regear??
Just a thought.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Mike71
  • 1449
« Reply #7 on: July 11, 2004, 02:01:01 AM »
well im pretty sure idaho will be taking plenty of pics of his 4door so i can learn =) and ill send him a disposable or 2 so he can take pics of the axel build up =)....and ofcourse when its all paid for and finally shipped to me i will take pics of it going in
it looks like itl take 3-4 months starting in 2 weeks =) thats everything..gears tcases everything but tires lol
the way we were talking i will run 35"s on the street and 33"s to wheel
hmmm what else...cant think of anything =) and suggestions post away
oh yah..i think that idaho was talking about maybe making a sas kit =) (hehe now ur in for it idaho lol)
Offline Mike71
  • 1449
« Reply #8 on: July 11, 2004, 03:06:20 AM »
i know this may be dumb..but when i go SFA do i still need locking hubs?? im kinda confused on that
Offline 1bigtracker
  • 3409
« Reply #9 on: July 11, 2004, 04:17:55 AM »
i have heard about longfeilds but never took the time to reserch them.  what are they and where could someone buy some(for a yota, not tracker).
stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: July 11, 2004, 05:52:22 AM »
Just a thought.
And you speak with what experience ?
Heather Galvin
Offline Natebert
  • 1098
« Reply #11 on: July 11, 2004, 06:07:02 AM »
Kimball,
This isn't a flamer, its just that I think that everything you just said is totally wrong.
Um yes it will.
I still rub on the frame front, AND back.  So no matter what coils I choose, I'll still rub with the stock sidekick width.  This means that I need a couple inches wider.  Wheel spacers or more backspaced rims, both of which are harder on bearings.
Broken plenty of these babies,  even at idle.  (no kidding here people).  No matter what Sidekick axles I choose (custom aftermarket, etc) breakage with my puny little motor is inevetiable.  So if I went bigger to start off with and Then custom on top of it.  I might not have as many problems.
Well when I've already paid for totally cutom stuff and it can't handle the mustard.  I might have started with bigger custom stuff to begin with.  With a 180:1 craw ratio, I don't think that anything Suzuki sized is going to handle it.
So fullsize landcruiser stuff might be a better solution (only thing I know of with the proper offset diffs, which is bigger then what I've got)
Just a thought.
And how much money did YOU spend for this 'thought"?  Seems to me that your truck with the standard solution has NEVER been driven.  The only prototype that's been generated from 'IDAHO' and actually trailed, (lightly mind you) has been plagued with problems.
Just a thought and an opinion from a guy who's really been there and done it.
Again,
That way, I'd have all of my width and strength issues already taken care of without going totally custom.  THEN if I needed something stronger I could find other solutions.
But as it is right now, what I've got is just about as good as I can get, no more upgrade path here.  Just more broken parts.
You'll thank me.
~Nate
« Last Edit: July 11, 2004, 06:17:34 AM by natebert »
Offline Mike71
  • 1449
« Reply #12 on: July 11, 2004, 06:39:43 AM »
gesh this topic heated up quite quickly..
the axels that will be used have a life time garentee..so they should be prety strong
couldnt u fix the rubbing by going with smaller tires??
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #13 on: July 11, 2004, 06:48:51 AM »
Why not 35's for trail(more ground clearance) and 33" for street(quicker acceleration than 35")??????
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline Mike71
  • 1449
« Reply #14 on: July 11, 2004, 07:25:04 AM »
i dont really want a HUGE lift..so clearing 35s would be a little harder
