Radiator hose
  • 1739 Views
Offline Mvjlt
Radiator hose
« on: April 14, 2010, 12:20:43 AM »
I have a 1987 Suzuki samurai jx I have been noticing that that upper and lower radiator hoses have been sucked flat after my Sammy is warm. I have replaced the radiator cap and thermostat. My question is, are the stock radiator hoses a hard plastic or a hard rubber. I was looking on petroworks.com and they had a hard plastic radiator hose. (mine are rubber) I will probably end up replacing both the upper and lower hose anyway. Do yall know a trusted place on the net to buy them?
Offline 89tracker43000
  • 47
  • my tracker
Re: Radiator hose
« Reply #1 on: April 14, 2010, 05:55:31 AM »
they should not suck flat that usely means that your low on coolant and there is air in the system. regardles of rubber or plastic
Offline Mvjlt
Re: Radiator hose
« Reply #2 on: April 14, 2010, 12:05:55 PM »
The problem is since the hoses are flat it won't suck any fluid back from the over flow tank. If there was air in the system how would I get it out
Bobthebiker
Re: Radiator hose
« Reply #3 on: April 14, 2010, 12:22:31 PM »
I'd start by replacing the hoses, use rubber hose. I've never heard of plastic coolant hoses, so I naturally dont trust em.
then burp the cooling system.
Offline woof359
  • 111
Re: Radiator hose
« Reply #4 on: April 15, 2010, 09:17:59 PM »
replace the radiator cap, the problem shood go away, we run into this on older Toyptas all the time at my shop.
CHUCK AND MICHELLE
