Steering U J
  • 1566 Views
Offline Sn0vv
  • 143
    • Cardomain Profile
Steering U J
« on: April 23, 2010, 11:46:43 AM »
need to know Steering U joints that fit a 2000 2.0l chevy tracker part #s and where I can get decent ones.....apparently I cannot buy factory U joint without having to buy the whole assembly (which I believe is BS)  any help welcome guys........thinking Junkyard but i am sure since the joint is exposed that junkyard parts of this nature are not wise......
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline sir lance
  • 342
  • I love my XL-7
Re: Steering U J
« Reply #1 on: April 24, 2010, 07:57:24 PM »
the u joints are non replaceable because the bearing caps are crimped into the ears on the yolk. basically its a non servesable 1 piece unit.
and getting one from a wrecker should be fine, its ok for them to  be "exposed" because there is a rubber seal around each bearing cap.
no different than the u-joints on your driveline.
-lance
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Steering U J
« Reply #2 on: April 25, 2010, 03:01:07 PM »
X2 on grabbing another from your local junkyard/pick-n-pull.
I got a steering u-joint assembly WITH a rack and pinion unit I bought, all for $75 bucks from one of my local P-N-Ps.  You can always check the u-joints for free play after you remove them from the wrecked truck.  If they move freely then you should be good to go.  In fact, I would recommend grabbing the R&P unit at the same time if they are both there.  Usually the steering linkage gets yanked with the column or is at least removed or lost.  The R&P in your truck will probably go sooner or later as well, plus, if you take a pickle fork with you and separate the tie rods ends from the front hubs, you will also have a couple of tie rod ends for future use as well.  I poured power steering fluid into my R&P and cranked it back and forth by hand  to (hopefully) keep the seals moist until I use it.
