Who makes the best SPOA kit?
  • 20 Replies
  • 6762 Views
Offline igaug
  • 40
« on: April 26, 2010, 12:38:50 PM »
i just bought an 88 samurai and am new to samurais in general. have always been a fan though. the samurai i bought has a cobbled together lift on it and i want to do the SPOA lift but don't know much about the manufacturers that sell the kits. i have looked at petroworks and rocky road quite a bit. what are your opinions on them? are there other manufacturers that are worth looking in to?
Offline joe dirt
  • 148
Re: Who makes the best SPOA kit?
« Reply #1 on: April 26, 2010, 01:22:43 PM »
sky mfg
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
« Reply #2 on: April 26, 2010, 01:43:17 PM »
I agree, the basic SPOA kit from Sky will give you everything you need to get going.
Offline igaug
  • 40
« Reply #3 on: April 26, 2010, 02:04:29 PM »
with stock axles, and transfer case gears are 32's too big?
Offline igaug
  • 40
« Reply #4 on: April 26, 2010, 02:33:05 PM »
also how what size of tires can you fit with the sky kit?
« Reply #5 on: April 26, 2010, 03:37:31 PM »
Standard is 31" tires for most SPOA lifts, but I was able to squeeze 33" tires on my SJ-410 with a bit of trimming of the rear fender wells back in the day.
Depending on what you are planning on using the rig for you can probably get away with the larger tires, but the freeway will be a bit beyond your grasp.  I would recommend looking at the 5.8 or 6.5:1 t-case gear set.
There is a really good write-up at http://www.zukiworld.com/forum/general-suzuki-forum/basic-spoa-on-a-lwb-sj-413-using-stock-parts/ of Kahn-Sultan did of his own SPOA lift.  It should cover a lot of your questions.
As for the Sky Manufacturing kit, I recommend picking up the State 2 kit at http://www.sky-manufacturing.com/new/detaproduct.php?id=92 to get started.  It gives you everything you need to get going quickly and easily.
Offline igaug
  • 40
« Reply #6 on: April 27, 2010, 09:00:27 PM »
why do you guys like sky better than rocky road or petroworks? just curious...
« Reply #7 on: April 27, 2010, 11:17:11 PM »
I like their wrap around spring pad's.  Having ripped a normal one off the axle the extra bracing is a nice touch.  Plus it makes it easier to mount as it is already lined up.  The new steering setup is a nice touch as well.
But any of the companies kit will work.  The Sky pads are just nicer in my opinion.
Offline igaug
  • 40
« Reply #8 on: May 05, 2010, 09:32:14 AM »
the sky stage 2 kit does not come with shock or mounts... will my stock shocks work with this kit or should i just look in to the stage 5 kit that does come with shocks and mounts?
« Reply #9 on: May 05, 2010, 12:00:59 PM »
Your stock shocks will work just fine.  You just swap your spring pads from left to right and everything bolts right up, you just won't see the long travel.
I would wait on the longer shocks and instead look into a traction bar for the rear end to avoid spring wrap.
Offline igaug
  • 40
« Reply #10 on: May 05, 2010, 02:08:48 PM »
the rear is already sprung over with stock shocks that bottom out everytime is hit a crack in the road. the front looks like someone cut the leaf mounts off the body and welded 3 inch square tubing to the frame, then reattached the spring mounts. looks terrible and i want to redo it all. what exactly is spring wrap? ive read a lot on preventing it but not sure what it is? thanks for bearing with me here!
« Reply #11 on: May 05, 2010, 03:10:25 PM »
Can you post some pictures so we have a better idea of what we are looking at?  There might be something off in how the rear shocks are mounted and it would help to be able to figure out how your front end was hacked up.
Spring Wrap is when your rear springs turn into an S instead of a gental curve.  It usually comes from hill climbing when the back of the rig rig starts bouncing around, the springs were not designed to be in a spring over axle configuration so they are kind of weak against the axle rolling under the spring.  I bent up two sets of rear springs before switching to a 4 link in the back.
Offline igaug
  • 40
« Reply #12 on: May 09, 2010, 03:18:25 PM »
here is the rear shock setup
Offline igaug
  • 40
« Reply #13 on: May 09, 2010, 03:20:15 PM »
and this is the cobbled together front, let me know what you think of this work! lol
Offline Amilla
  • 1076
« Reply #14 on: May 09, 2010, 07:38:04 PM »
Looks like some solid work to me. ::)
Amilla
